Question about Whirlpool LGB6300 Gas Dryer
LGR8648P0 does not get heat - Whirlpool gas dryer
Posted by sheacole27 on
D. Floyd Kolb
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
Whirlpool duet electric dryer turns on but doesn't
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Whirlpool Dryers
Gas whirlpool dryer model LGR6611LQ0 will not heat up . Ignitor turns on but will not light
heatman101
Dec 19, 2010 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer lgr7646dq1 is working but will not heat
heatman101
Nov 20, 2010 | Whirlpool GGW9200L Gas Dryer
I replaced the fuse and the coils for my Whirlpool dryer because it would heat up and then the flame would go out after it ran for 5 - 10 minutes. Now what could it be? Whirlpool Gas Dryer LGR8648LW0
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 19, 2010 | Whirlpool Dryers
Our whirlpool dryer has no heat. Is there a
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 28, 2010 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Craetions Dryer AWZ129: No Heat
heatman101
May 15, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool gas dryer LGR7648KQ
heatman101
Jan 17, 2010 | Whirlpool LGR7648KQ Dryer
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
Whirlpool gas dryer will not heat up?
How do I take apart a kenmore gas front load dryer, to get to the fuses, heating element etc. Model # 417.91042000. Please Help... Thank-you
Nov 10, 2008 | Whirlpool Dryers
Whirlpool LGB6300 Gas Dryer Logo
122 people viewed this question
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
