LG LFX23961ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
Question about LG LFX23961ST Stainless Steel Bottom Freezer French Door Refrigerator
LG Refridge LFX23961st
Just installed LG Refridge LFX23961st with French Doors and Bottom Freezer. Compressor whines when starting (about 5 seconds) then sound abates and refridge is extrememly quiet. LG says it is normal for compressor whine on startup, but no frgide I ever had made this sound. Is it normal? Thanks.
Posted by frankm1000 on
DocZachary
    Master:
  • 533 Answers
LG LFX23961ST Support Manuals Warranty More LG
I just used the link above to get the Manuals on your LG. On page 31, they did the following CYA statements...
The defrost timer will click when the automatic defrost cycle begins and ends. The thermostat control (or refrigerator control, depending on the model) will also click when cycling on and off. Rattling noises may come from the flow of refrigerant, the water line, or items stored on top of the refrigerator .
Your refrigerator is designed to run more efficiently to keep your food items at the desired temperature. The high efficiency compressor may cause your new refrigerator to run longer than your old one, and
you may hear a pulsating or high-pitched sound.
You may hear the evaporator fan motor circulating the air through the refrigerator and freezer compartments.
As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your refrigerator.
Contraction and expansion of the inside walls may cause a popping noise.
Water dripping on the defrost heater during a defrost cycle may cause a sizzling sound.
You may hear air being forced over the condenser by the condenser fan.
You may hear water running into the drain pan during the defrost cycle.
I bolded the statement. Sounds like you are going to have to get used to the sound.
Semper Fi,
Z
Posted on Feb 01, 2018
4 Related Answers
Anonymous
  • 1056 Answers
SOURCE: Freezer section is working but refridge not very cold.
check the vent that lets air from the freezer goes to the refrigerator. A control knob operates the amount of opening through the vent with a flap. makes the flap is not stuck, and responds to the knob, this is all mechanically link.
Posted on Jun 30, 2009
Anonymous
  • 15 Answers
SOURCE: refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Posted on Jul 24, 2009
Anonymous
  • 363 Answers
SOURCE: Loud compressor noise from lg frig...
The sound you hear is the Freezer Fan, this problem is hard to diagnose, because the fan spins but not fast enough to circulate chilled air thru the freezer and refrigerator. The minimum labor and material cost for the repair/replacement is around $300.00. But if you chose to make the repair yourself the motor alone costs around [email protected]. But the repair is very labor because the electrical connection for this fan is at the rear of the unit
Posted on Jul 31, 2009
Anonymous
  • 1543 Answers
SOURCE: GE Refridge #tbx21jablraa Water collecting in
The defrost drain tube is plugged. Move the refrig out from the wall and remove the tube which goes from the center middle of the back to the bottom part of the refrig. Clean out the tube and check the part that goes into the refrig. That part usually comes off with a quarter turn or so, then pull.
Posted on Sep 24, 2009
1helpful
Refrigerator starts and I can hear the compressor running but after maybe 3-5 min. an error comes up and unit will not opperate ERR is on display
sounds like compressor is over heating, may be dirty around it reducing cooling air or it could be the compressor is going bad
Why does it keep blowing fuses?
your unit either has shorted wirings , grounded compressor or fans. thanks.
Error message: Er 1F
You have a problem with the ice room fan motor. It will not send freezing cold air to the icemaker. You will need to have a qualified technician replace the fan motor.
Good luck
Energy rebate payments
HI. you will qualify only if you installed a genuine LG part and, it was installed by a certified LG tech. That's the only way to qualify.
Refridge and freezer stopped cooling
it is either the start switch on the side of the compressor or the compressor itself.
the buzzing sound is the start switch trying to start the compressor and the click is the overload on the start switch kicking it out.
the start switch is bad or the compressor is pulling too much amps = bad compressor.
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
