Aiptek Mini PenCam Digital Camera Logo
Posted on Mar 08, 2010
Lack of drivers to Aiptek 1,3 for Vista
I ask for the help in the obtainment of proper drivers because I will do the dance away the "splendid " system . Thank you for help ;) .
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7547
Points
16
Original driver of aiptek dv 3500 model where?
You can download driver for your camera from Aiptek support here :
http://www.aiptek.com/drivers.htm
But I can't find DV 3500 though, but there are DV 5300 and DV drivers. You can choose proper driver for your device.
Hope this help and if helpful RATE please.
Need driver for vista cant find them any where
You don't need one. It's Plug&Play on Vista.
1helpful
I have a camcorder that says it has webcam capabilties, but i dont know how to use it or even find how to use it! the camcorder is the brand Aiptek the make is ISDV2.4 where can i find the webcam???
Install the driver software on your system. If you don't have it, you can download it from aiptek.com under the support tab.
If you have windows vista be sure to set the setup.exe compatability to windows xp before trying to install. (Right click on setup.exe, go to 'compatability' tab, set to windows xp, click ok.) If you already installed it on vista without setting the compatability just run the setup again and choose the 'remove' option, then reinstall it with the correct compatability.
Once the drivers are correctly installed a shortcut should be added to your desktop labeled "DV TS". You can open this to check that the driver is working properly. Be sure to have plugged your camera in through the USB port next to the SD card slot.
At this point if everything has gone well, then you should be able to select it as a video source in whichever Instant Message program you choose to use. Providing that program supports webcams.
-Refer to the IM program's help file for instructions on how to select a video source / web cam.
1helpful
Install aiptek PocketCam 1.3 in vista
The following drivers are supposed to work on Vista, they are not from manufacturer.
If this driver does not work on Vista, then the camera is not Vista compatible:
Aiptek PocketCam 1.3 Driver for Windows 9X/ME/NT/2K/XP/2003/Vista
Drivers for windows vista
You dn't need one. The 5700 IS-DV is plug&play. For details see
http://www.aiptek.com/Supports/Driver/Compatibility/
Top Aiptek Cameras Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
