Question about Bosch Washing Machines
There is a key symbol on the display panel and a beep,the machine will not do anything
Posted by harrhybale on
Anonymous
    New Friend:
Key + beeping = child lock has been activated.
To clear this
1. close washing machine door
2. turn dial to usual wash setting
3. press start button and keep pressing for several seconds - the problem should be solved.
Good luck
Jess
Posted on Apr 07, 2010
2 Related Answers
prem mathew
  • 1294 Answers
SOURCE: Washing mashine dispalys symbol not in users
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Posted on Mar 30, 2009
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: Bosch Exxcel WAE244S0GB machine won't start,
Hi
If the beep sound is coming from the dial not from the bottom where the motor is then the issue seems to be with the Timer/control board going bad and needs to be replaced. However, you can unplug the unit and then blow some air with the help of hair dryer before replacing the Timer motor/control board. If the sound comes from the motor area then it is the motor that has gone bad and should be replaced. When the motor goes bad it will fill with water and empty. One more thing to check will be the door lock-switch assembly, because if the control detects door not locked it won't run cycle and will just drain the water out. Also please let me know the exact key symbol before 0 which is appearing on the panel. Hope this helps... .please post back for further assistance.
Daniel
Posted on Jan 09, 2011
Machine will not start. Showing key symbol and beeping.
Child lock is on. Press and hold the child lock on the user interface for 5 seconds.
Dec 15, 2014 | Bosch Washing Machines
Kenmore ultra wash machine won't run even with indicator lights on. Symbol on machine says Lock on
You have the control-lock function turned on. There should be a key located near (above or below) the lighted lock symbol. Usually, it's the Heated Dry button. Whatever it is, press and hold that key for 5 seconds. That should unlock your dishwasher and you can now use it normally.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 15, 2014 | Kenmore Dishwashers
I have a double draw dishwasher . the child lock key comes up and the dishwasher does not start
The lock button activates/deactivates the Keylock or the Childlock functions. This button has either a key or a padlock icon. I believe that on this model it is a padlock
Keylock
The Keylock feature disables all the buttons on the control panel.
To activate, press and hold the button until you hear one beep (3 seconds). The symbol
appears in the electronic display when the Keylock feature is activated.
Childlock
The Childlock feature locks the drawer and disables all the buttons on the control panel.
To activate, press and hold the button until you hear two beeps (5 seconds). The symbol
appears in the electronic display when the Childlock feature is activated.
To cancel the Childlock feature, press and hold the button until you hear one beep and the
symbol disappears from the electronic display.
This information can also be found in your product's Use and Care manual. If yours has been misplaced you can download or print one from Fisher and Paykel's website. http://www.fisherpaykel.com/customercare/userguide/index.cfm
If this doesn't work... And I've seen these units do some odd things. Try unplugging it for about an hour (if plug is not under sink you can turn of the breaker that powers the unit). Then plug it back in and see if that works. These dishwasher like many modern day appliances have solid state microprocessors in them which sometimes need reset just like a computer.
Hope this helps.
May 17, 2011 | Fisher and Paykel 23 in. DD603H SS...
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
There is a key symbol and I cannot start my next load
Hello and welcome to Fixya.
You`re likely right on about inadvertently locking out the controls. Your washer has a "child lock" program and I suspect that has been activated.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the start/pause button the key symbol should disappear confirming you have successfully exited the child lock program.
If this indeed was the issue preventing you from operating the washer you should now be free to select any cycle and carry on.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
May 07, 2010 | Bosch Classixx WFL 2066 Front Load Washer
A key symbol has displayed on my panel and the dryer will not work. Not sure what I need to fix. opened door to take out some clothes and now it won't start up againg... beep beep and key shows
the door lock has gone it sounds to me the dryer wont work unless the door is shut so if its not picking that the door is shut then it wont work
hope that helps :)
Oct 15, 2009 | Dryers
Won't start, key symbol in display panel
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks
May 16, 2009 | Audiovox Bosch 718 World Cellular Phone
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Rinnai Avenger 25TR Model Gas Heater
I just fixed this problem for my parents. All you have to do is hold the up and down arrows that sorround the power buttom for 3 seconds at the same time and the key symbol should dissapear and make a slight beep. Then you should be able to use the heater as normal =]
May 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Washing Machines Logo
589 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
