Question about Texas Instruments TI-84 Plus Calculator
How do you do conversion on this calculator? - Texas Instruments TI-84 Plus Calculator
Posted by rfuller_38 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
If you have the SciTools app loaded:
Press APPS, then select the SciTools app. Press any key to continue. Press 2 to select the Unit Converter. Press digit/letter to select the type of unit to convert.
Enter the number. Navigate to the unit. Press ENTER. Navigate to the unit to be converted to. Press ENTER to see the result.
If you don't have the SciTools app, you can download it from the manufacturer's web site at http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&tabId=1&appId=205
You can also download the guidebook for the app from the same page.
Posted on Mar 09, 2010
1helpful
HOW VOLUME CONVERSIONS ARE DONE?
On the calculator there are conversions of capacity (gallons (US or UK) to liters, liters to gallons (Us), gallons(UK) but there are no conversions from ft^3 to m^3. However you have the basic conversions from in to cm, cm to in, yd to m and m to yd. That is all you need.
To use the calculator to perform a conversion from ft to meters, you enter the number of feet, you press [SHIFT][8] (Conv).
The calculator prompts you to enter a number between 01 and 40. Each number corresponds to a particular conversion. In this case you enter 03
For example convert 3 ft to meters.
Enter 3
Press [SHIFT][8] (Conv)
Prompt: CONVERSION Number 01--40
You enter 03 (ft to m) and press [=]
Calculator displays 3 ft >m, and on the second line 0.9144
Thus 3 ft=0.9144 m
Once you know how to convert one unit of length to another, you get the volume by raising conversion to the 3rd power.
For this to work, you must convert all dimensions to the same unit.
2answers
Square feet converted to square metres
Simply square the conversion factor between feet and metres to get the conversion factor between square feet and square metres.
One foot is 0.3048 metres, so squaring that gives one square foot is 0.09290304 square metres.
2answers
I need to know how to convert 11390cm cubed into metres cubed
Your calculator may or may not have a program for unit conversion, but the best method is to understand the metric system so you can do these conversions without a calculator. A meter is the same as 100 centimeters, so divide 11390 by 100 to get 113.90 m^3.
Rather than relying on a calculator, I highly recommend taking the time to practice metric conversions. It is very common for high school and even college professors to try and trick you by, for example, requesting the answer in centimeters when the question is in meters.
1helpful
The vatican city is the smallest independent country in the world. it has an area of 47.90 ha. what is the area of the vatican city in in2?
About 742 million.
Not all the conversions are built into the fx-115ES (the list of conversions is printed on the inside of the calculator cover), but here goes.
First, if you don't know it, get the conversion factor from meters to inches. There's no single conversion for this on the calculator, but one way is to convert from 100 cm to inches by pressing
1 SHIFT 02 =
Store this result for future use by pressing
SHIFT RCL (-)
A hectare is 10000 m^2, so 47.90 ha is 479000 m^2. Now convert this to in^2 by multiplying by the square of the stored result. Press
4 7 9 0 0 0 * RCL (-) x^2 =
And you'll see the answer.
2helpful
2answers
Convert metric weight to pounds
1 Kilogram (Kg) = 2.20462 Pounds (Lbs)
1 Pound = 0.453592 Kilograms
See the following links for Online Conversion Calculators:
http://www.metric-conversions.org/weight/kilograms-to-pounds.htm
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Good luck.
6helpful
2answers
Trying to use unit conversion feature and can't figure out how to use the feature
Assuming you want a conversion listed on the inside of the case:
Enter the value to be converted, press SHIFT 8 to bring up the conversion screen, enter the two-digit number for the conversion, then press =.
For example, to convert 2.1 inches to centimeters (conversion 01):
2 . 1 SHIFT 8 0 1 =
and see 5.334
2helpful
How to convert on casio fx-115es calculator
You have 40 possible unit conversions (20 one way and 20 the opposite way).
Each conversion operation is identified by a unique 2-digit number: for example, 01 is the conversion from inches to centimeters and 02 is the conversion from centimeters to inches.
For the whole list consult your manual or the quick reference card that is inserted in the calculator slide cover.
To convert 5cm into inches
  1. Enter the number 5
  2. Press [SHIFT][8] to activate (CONV)ersion screen
  3. You will be prompted to enter a two digit number between 01 and 40 (You must enter 01, 02,03, ...,09)
  4. In this case you enter [02] to convert cms>in
  5. and you press the [=] sign to execute the conversion.
It stands to reason that you only convert between units as directed in the table.
TI-84 has problems converting between rectangular and polar. is there a fix for this?
The conversion from rectangular to polar coordinates requires the calculation of an angle . If the angle unit that the calculator is configured for is different from the one you have in mind, you get (not erroneous results) but unexpected ones.
If the angle unit under [MODE] is radian, the angle you get in the conversion is in radians. Similarly, if the angle unit is degree, the angle obtained after coordinate conversion is in degrees.
Check your angle unit and restart your calculations.
1helpful
Binary conversion
In the FX-300Ms manual, the same for the FX-82MS, there is no way to use base-n (binary, octal, hexadecimal) calculations.
Sorry.
Texas Instruments TI-84 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Filipe Polido
Filipe Polido
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
