Our Philips 42-inch plasma (about 4 years old) is flashing colors. After some time with good picture it would go dark except for the top half of the screen which would flash colors. We would let it sit for some time and it would be fine. Now it is dark with flashes on the right half of the screen and is not getting better.
SOURCE: 42 inch LG Plasma TV - Lost picture
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
SOURCE: problem with philips 42 inch plasma tv
if you go and download the new firmware it will take care of the red light problem. firm ware upgrade version 1.5.0.0
SOURCE: pink vertical line down my 42 inch digital plasma
I do believe the Panel is bad and needs to be replaced. Check with the manfacture to confirm this.
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: emerson 42 inch plasma (Walmart special) need code
Try the Samsung codes that are in the manual for the remote. The Emerson is a rebadge of a Samsung. My Dish remote worked poorly with the Emerson codes but the first Samsung code I tried worked beautifully! :)
