Question about Microsoft Xbox 360 Arcade
My tv runs on pal50 but some games on xbox360 run on pal60 , how do i play these games on my tv
Posted by jhaddy on
Anonymous
    New Friend:
  • 34 Answers
Standard definition TVs loadTOCNode(2, 'moreinformation'); If you connect your Xbox 360 console to a standard definition TV, follow these steps to set the Xbox 360 display settings to PAL 60 Hz:
  1. Turn on the Xbox 360 console.
  2. In the Xbox Dashboard, select System, and then press the A button.
  3. Select Console Settings, and then press the A button.
  4. Select Display, and then press the A button.
  5. Select PAL settings, and then press the A button.
  6. Select PAL-60, and then press the A button.
  7. When you are prompted to keep these new settings, confirm the settings, and then press the A button.
Note Some older TVs do not support PAL 60 Hz. If you do not know whether your TV supports PAL 60 Hz, contact the manufacturer of your TV or see the owner's manual.
Posted on Mar 13, 2010
Game will not play as it requires pal50 to pal60
The region locking on the game doesn't match your console. For example, you have a USA 360 and a European version of the game. There's no fix for this, so you'll need to buy a copy of the game that is compatible with the region of your 360. Hope that makes sense...
Feb 15, 2011 | Microsoft Xbox 360 Console
Can i change pal from pal50 to pal60
The TV should do that automatically as you play the video/dvd.
Jan 02, 2011 | Televison & Video
Tv works on pal50 how can i play pal60 games
if tv only works on pal50 the simple answer is you cant play pal60 games
sorry
Mar 01, 2010 | Microsoft Xbox 360 Console
Change 360 to pal60?
once on the dashboard go to system settings,console settings,display,pal settings and change it between pal50 and pal60 hope this helps you out
Jul 18, 2009 | Microsoft Xbox 360 Console
It is on my tv it does the same on all tv
You Xbox needs to be factory resetted it is stuck on DVD mode so start the consol and format the hard disk.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Video Game Consoles & Games
Xbox 360 freezes
have you tipped the xbox360 over while playing it
Feb 10, 2009 | Microsoft Xbox 360 Console
Xbox Does not play original games
Error Codes XBOX360
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Feb 25, 2008 | Microsoft Xbox 360 Console
XBox360
I don't think you'll have any problems with burn in on a rear projection TV. CRT and LCoS type televisions can have burn in problems
Dec 10, 2007 | RCA D52W19 52" Rear Projection Television
How to change from PAL-50 to PAL-60?!
i have a xbox 360 and a television that opperates at PAL-50
my xbox is telling me, to play a game i must operate at PAL-60.
when i change the xbox settins to PAL-60 the televison goes all fuzzy, can i fix this.
Apr 14, 2007 | NEC MultiSync LCD1550VM 15" LCD Monitor
Microsoft Xbox 360 Arcade Logo
233 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
