Where can i buy a chain guard to replace the one that came on the trike? - it got bent into a pretzel. also, WHERE can i get a 3 or more speed conversion kit for the bike? - i saw on the www. that there IS such a kit, but cannot find out where & how much. thanks, PrestigeGunleather
On the very back of the frame there are two bolts, one each side, pointing in the direction the trike rolls. (See the attached photo), These are adjusters for chain tension and alignment, like on a motorcycle. Slacken the axle nuts then wind the bolts on the end to slide the axle forward. This will give you the slack you need to remount the chain. **Note** Keep count of the number of turns you make as you wind the adjusters off and on. If the gear isn't lined up straight to the frame it will keep throwing the chain off.
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - 5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Find the master link first. It will be the only one without the hourglass shape (flat on the sides) I just use a needle nose or a screw driver and a light tap with a hammer using the screw driver as a wedge. Using this method make sure to keep your eye on the master if it flies off.
Sounds like the blade brake is engaged. You should be able to pull the blade brake handle, located on top of the saw, in front of the top handle, back towards the handle to disengage it. You can find replacement bars, chains & sprockets for your saw at Partsbuggy.com.
You can use a screw driver to release the yellow plastic plate at the bottom of the frame, you can remove it just enough to use the same screw driver to press the little button in a release the wheel
