Question about Troy Bilt Tb70ss Gas Trimmer
How do i put on new string? - Troy Bilt Tb70ss Gas Trimmer
Posted by admryan3 on
How do I get the trimmer head open?
Turn the knob in the middle of the head anti clockwise and the string reel should come out.
Aug 21, 2015 | Garden
Tip
How to string an electric guitar
I'm writing this tutorial to help new guitarists string their electric guitars.<br /><br />The first step is to purchase some strings from your nearest music store, depending on the type of music you want to play the string gage will be different. If you want to play heavier music such as metal then I suggest using a heavier gage of string. If you want to play calmer music such as indie, or maybe soft rock I suggest a lighter gage.<br /><br />Next make sure and remove <span style="font-weight: bold;">ALL</span> existing strings. The best way to take off the old strings is to simply loosen them up then cut them right in the middle with wire cutters. Then just pull the left end through the tuning knobs, and the right end through the back of the guitar (Note where the strings come out of the back).<br /><br />After you have removed all the strings its time to put on the new ones. Start with the string closest to the top of the guitar. On your string package you can reference by color which string is which. Find your string then run the sharp end through the back of the guitar in the hole relative to the string you are putting in (These holes in the back are the same holes the old strings came out of). Run the string all the way through so that it is pulled tightly into the back. Now place the sharp end of the string through its relative tuning knob at the top of the guitar. You should pull enough through so that when you pull the string up off the neck there is a gap of about one foot. Now turn the tuning knob clockwise until the string is relatively tight against the neck and it has wrapped around the knob 3-5 times. Now cut the excess string that is coming out of the tuning knob but leave about 1 inch in case you want to lower the tuning. <br /><br />Do the same thing for all your strings, then tune them with either a digital tuner or by ear if you can. You can purchase a cheap digital tuner for around $20 at your nearest music store.<br /><br />Enjoy!!
on May 16, 2011 | Yamaha Electric Guitar
I Have a Weed Eater Model W25CFK I need to put new string on it ...It doesn&#39;t have a spool you use two individual pieces of line and I can&#39;t remember how to do it and can&#39;t fi
There are a couple of different heads that doesn't have a spool on 1 you pull the left over pieces of old string out from under the and the push the new short pieces into the front of the head, another you line up two arrows and then put a long piece of string throw the head eqail on both sides and then wind the head to pull the string in, another you take off and feed the line down inside.
Oct 13, 2014 | Garden
How to change the strings onthe epiphone professional deluxe mandolin
You can slide the silver plate straight back by gently pushing it from the top with your fingers. Once it slides off you will then be able to see the hooks that you put the new strings on (loop end strings). Once strings are tightened, you slide the cover back on the same way you slid it off. There is a small piece of felt glued to the cover. Be careful not to knock it loose when you are putting the cover on.
One other tip, change one string at a time instead of pulling all of them off at once. The bridge will come loose if you take all the strings off at once (it is not glued to the mandolin).
Feb 17, 2012 | Epiphone MM-50E Professional Mandolin
Please describe your issue or question (*) Last year we bought four of the Gemmy Color Chasing Light Show strings with the multi-color LED tear-drop shaped bulbs (#0293751). All four strings worked...
tombonw, I noticed this problem last year also, did the same string replacement as you, but by seasons end the new strings I bought had the same problem with a few doing something different. Did you ever find a good solution or hear from anyone else?
Dec 07, 2009 | Gemmy Toys
My tele tuners have a slot in the tuners. I am
Usually you have either loops or little metal spools in loops at the end of the strings. The little spools are put down into the slots to secure the strings. If your old strings have the spools, you can remove them and put into your new strings.
Sep 29, 2009 | Fender '72 Tele Deluxe Electric Guitar
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Don't know how to install new string on Echo SRM 2400
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
I have a robi 31cc don't know how to put on new string has double head i can't put the string on
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 15, 2009 | Ryobi Garden
Can't figure out how to put on new string after i took off the old string
I figured it out. Went on YouTube and watched a couple videos and did it myself. Thanks!
May 17, 2009 | Craftsman Garden
Troy Bilt Tb70ss Gas Trimmer Logo
372 people viewed this question
Top Troy Garden Experts
colesmowers
Sheldon Dedek
Dennis Key
Dennis Key
Are you a Troy Garden Expert? Answer questions, earn points and help others
