I would like to play my ipod through the aux in socket using a purchased adapter but I cannot select aux in on the radio. The manuel seems to suggest that this is because a CD player is built into the radio. Is it easy to disconnect this?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
I think the only hope you may have is the radio has an auto signal select in the menu somewhere. You can't use the mute wire as that will mute the AUX as well.
It took me a while to figure this one out. Firstly plug your device in to the aux socket and play some music so you can hear when it's correctly switched over. Turn on the iwantit using the switch at the back then press the play button once, you should see the lights on the buttons go brighter. Now press the play button again, this time holding it down for exactly 3 seconds. When you release the button you should be in aux mode and you should hear your music playing. Hope this helps, it took me about an hour of faffing around before I finally figured it out.
You need to plug the iPod into the Aux socket, its on the front bottom right corner. Then you can switch by pressing "Mode" between playing either the CS - USB - SD - AUX.
The RCA jacks on the back of the Pioneer DEH-1500 are preamp outputs, not inputs. They are to connect an external amplifier for additional speakers or subwoofers.
The output from your iPod is probably "bleeding over" into the receiver detector stage. When the antenna is disconnected, the signal passes into the amp by itself. Connecting the antenna provides enough signal so that both are amplified.
To connect the iPod, you need to purchase a wireless iPod adapter, or a new head unit that includes an "AUX" input or a dedicated adapter for the iPod.
Check Radio Shack, thay make an adaptor with a white and red audio plug that can connect to an input on the receiver (AUX) the other end goes into the headphone jack on the iPOD.
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
