Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
Anonymous Posted on Mar 07, 2010
Fdfdg gfd gdfgdfg fd dfs gdfgdf - Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Mar 07, 2010
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2149167
Points
26471
Hi
Thanks for using FixYa. It seems that you have some issue with your Sony Bravia LCD TV however, you have not written anything about it. Please revert with a detailed question so that I can assist you in a better way.
Thanks Rylee
Have an lg dfs unit not working cooling lamp flashes 7 times heat lamp 6 times what is the problem?
DEFINING COMMON ERROR CODES www.lg-dfs.com/.../dfs-tp-ag-002-us_012h29_lgtechpaper_errorcodes-la... Aug 29, 2012 - Refer to Service Manuals posted on www.lg-dfs.com to troubleshoot individual error codes. Error. Code. Description. No. of Times Indoor Unit ...
WHICH IS COLDER 1 OR 7
gvfdhdfgdf
gdfg
dfg
df
gdf
gd
gdf
gdf
gdf
gdf
g
fdgd
fg
fgfg
fgdf
gfd
gdf
gd
gdf
gdf
gd
fgdf
gd
fg
fdg
dfgdf
gfd
gf
g
dfg
fgfdgfgf
fg
g
g
df
gd
f
fg
f
g
i think you should google it
WNDR3700v2 cannot change region
Why does the WNDR3700 only support 4 channels in 5GHz if the wireless region is Europe, 8 channels if wireless region is United States at "Up to 300Mbps"?
Other 5GHz channels are DFS channels. There are government radars working in those channels. Without passing DFS certification test, we are not allowed to open those DFS channels. We are doing DFS certification and we can open those channels by releasing new firmware after we get DFS certification in the near future. You DO NOT need to change hardware, but just upgrade the WNDR3700 firmware to the new one which supports DFS channels. However, you still need to make sure your 5GHz wireless adapter can support DFS channels. Otherwise, you still can't use those channels.
In short you need to upgrade the firmware :
Here's the link http://support.netgear.com/product/WNDR3700v2
1helpful
DFS in AD (Active Directory)
Microsoft has a step by step guide to setting up a Distributed File System.
http://technet.microsoft.com/en-us/library/bb727150.aspx
There is also a very good FAQ available which will help you learn all about DFS.
http://www.microsoft.com/windowsserver2003/techinfo/overview/dfsfaq.mspx
3helpful
3answers
Error 03
i had same error,display 1.02 then display Er03 . so i buy new ICPN20 ICPN25 replace PS1 and PS2,but no use.
where wrong with DFS-500
DFS
Basically because network file access to files on local networks (or geographically convienent locations) can speed access and or distribute network load this feature supports the creation and maintenence of multiple copies of data to facilitate timely access for a geographically distributed set of users. Depending on the size and user requirements this could be as close as replication between two buildings for higher volume use or as far as Europe or Asia for lower volumes of use to minimize internet traffic on could be relatively narrow and costly communication links between the continents.
Pioneer DEH-P4000 DFS Alarm driving me crazy
How to disarm DFS alarm How to disarm DFS alarm Disarming alarm Upon entering your vehicle and within the ENTRY DELAY TIME set within the DFS alarm Menu, attach your Pioneer Detachable face. If you have forgotten the Detachable Face Panel: If the STARTER DISABLE is ON, insert the ignition key in the ignition within the ENTRY DELAY TIME, then turn the key from OFF to ON 5 times within 1 minute. If the starter disable is OFF, insert the ignition key in the ignition and turn the key from OFF to ON within the ENTRY DELAY TIME. CAUTION: If the starter motor will not run, the cause may be the DFS alarm. To check whether the DFS alarm is cause, try switching the position of the switch installed according to the AVOIDING TROUBLE section of the installation manual. If the DFS alarm is the cause of the trouble, then the starter motor will run. In case, confirm DFS alarm operation in safe place. If there is no problem, switch back to its original position. If left at the newly switched position, some functions of the DFS alarm will not operate. If the starter motor will not run after switching the switch, something other than the DFS alarm may be causing the problem. Have the vehicle checked at a nearby dealer. ----------------------------------------------- Select the DFS alarm feature ON/OFF mode (alarm ) in the initial setting menu. Press the arrow (up) button to switch the DFS alarm feature ON. Press the arrow (down) button to deactivate the DFS alarm feature. Press FUNCTION button for 2 seconds to enter the DFS alarm setting menu These are a couple of things I found to fix this problem. Here is the link that I got them from: http://www.pioneerelectronics.com/pna/v3/pg/support/knowledgebase/0,,2076_310069579,00.html Hope this helps:) Jason
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
