First open the handset and disconnect the battery. Then reconnect the battery (just in case the connection is loose). Make sure that the battery is in the handset in the correct orientation.
How old is the battery in the handset? After a year (frequently), the battery must be replaced. This time includes the length of time the battery was in storage before you received it. If you add a comment with the model of the Uniden phone, I will be glad to provide additional information on the cost of the replacement.
If the battery is new, then the charger may have failed. (I have seen this with many rechargeable devices.) Make sure the contacts are clean. However you may need to replace the charger. Again I need the model number to check if additional handsets are still available for the phone.
If your phone is under warranty, contact Uniden for repair/replacement of either the battery or the charger, as needed. Start at
http://www.uniden.com .
I hope this helps.
