The fuse in the power plug is there to protect the cable. The fuse in the plug should be the same as the cable. For instance a 5amp cable should have a 5amp fuse. If the fuse blows all the time the cable could be faulty or there could be an overload in the power supply (perhaps the transformer has failed) that is causing the supply to draw more amps than the cable and fuse can cope with.
WARNING fitting a fuse higher than the cable rating could cause the cable to overheat and catch fire!
