Question about Samsung CLP 300 Laser Printer
Samsung clp-300 Error message is "fuser low heat error
Posted by abdullah663 on
Anonymous
  • 526 Answers
The problem is that the Fuser is not heating up. Its possible you have a broken heat lamp.
The Fuser will have to get replaced, if you want to spend less but more labor, the heat lamp can be ordered.
Posted on Mar 11, 2010
Robert Allocca
    Sergeant:
    Champion:
  • 387 Answers
You are screwed unless you have a warranty. Samsung makes good products, BUT when you need a repair it's cheaper to buy a new one. My CLP300 Fuser rollers went bad, Samsung wants $135 plus parts for the repair. The fuser is $139.00. I only paid $141 for the printer. If I can find a fuser cheap I'll fix it myself. But Epson.
Posted on Mar 18, 2010
1 Related Answer
Nikolay Boychev
  • 525 Answers
SOURCE: Samsung CLP-600N displays message -
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Posted on Jan 21, 2011
I have an error message 'fuser low heat error' and the printer does not work. I have cleaned it up but can not get it to work
This is going to be a fuser replacement, or a dc power supply. The error you are getting is a direct result of the fuser temperature not reaching minimum temperature for fusing toner to the paper. This needs to be seen by a technician, as the current needs to be tested in order to figure out which part it is.
Sep 30, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-600N displays message - engine fuser low heat error. Machine is out of warranty.
Aug 10, 2010 | Samsung CLP-600N Laser Printer
Fuser low heat error
Hi and thank you for using fixya:
This happens when the fuser is not getting hot enough to start the printing process. This could be happening because the fuse is already failing. Try calling samsung see how much is a new fuser
good luck
Mar 23, 2010 | Samsung CLP 300 Laser Printer
Engine Fuser Low Heat Error on Samsung CLP-600N? What can I do?
i have samsung laserprinter 1610 problom low heat error ple telme anw
ser
Oct 05, 2009 | Samsung CLP-600N Laser Printer
Samsung clp-300 Error message is "fuser low heat error"
your printer toner is not installed properly. pls shake the toner & fix again.
Sep 01, 2009 | Samsung CLP 300 Laser Printer
Low heat fuser
The fuser is not heating up, a lamp could be out, but usually the rollers are worn and it's best to replace the fuser completely.
Jun 29, 2009 | Samsung CLP-510 Laser Printer
Low heat error
the fuser is defective and needs to be replaced.
Jun 11, 2009 | Samsung CLP-600N Laser Printer
Samsung CLP-315 system error
Low heat error comes from the fuser unit, there is a thermostat on the fuser change that and it will work
Mar 29, 2009 | Samsung CLP 315 Laser Printer
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
THERMO FUSE OR THERMISTOR DIRTY OR BAD
Nov 05, 2007 | Samsung CLP-550N Laser Printer
Samsung CLP 300 Laser Printer Logo
740 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
