Fluke Networks Fluke 179 Electricians Digital Multimeter Kit, Voltage Tester Logo
Posted on Mar 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a fluke 179 meter that was left outside and no longer powers up. Makes no sense as I don't think it was even rained on; morning dew. I've checked batteries and fuses and they are OK. What can I do? Is there a place that sells parts?
Robert Koch
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 165 Answers
  • Posted on Mar 07, 2010
Robert Koch
Expert
Level 2:
Mentor:
Answers
165
Questions
0
Helped
72216
Points
244
Try taking it apart and drying it out with a hair dryer, much as you would if your cell phone got wet.
No ohms on 179 fluke meter
check input protection (thermistor (black components - first in line at Voltage terminals should be around 1kOhm, next is 2W resistor = 1kOhm and then 3 varistors (blue) open or very high ohms).
I have a 2002 VW Jetta, it has a 2.0 motor. I've
REPLACE THE Ignition coil under $300 will fix it I just did it the clue is when it rains the coil has cracks in it and water shorts it out.
My fluke 179 shows batt in any function and it does not go out, with battery even new
send it back to Fluke for service if you are certain that battery is good and connector is not damaged (check Voltage on 2 pins that come to the board)
IT NO LONGER BEEPS WITH CONTINUITY OR CHANGING ANY
I have the older model but this may have the beep turned off......
4helpful
WHEN I TURN ON MY FLUKE 179 IT READS ERROR AND SHOWES CODE "EEPR" .
Hi, that is the error message indicating a EEPROM error and unfortunatlely, you can't do anything except have the meter serviced by either Fluke directly, or by an authorized Fluke test equipment dealer.
Since Fluke doesn't provide the specs and coding for their products, you wouldn't be able to repair the meter properly, even if you could burn and program your own chipset.
Here's a copy of the manual for your meter, so you can contact Fluke for servicing and see the other info relating to it (for your future reference)
http://assets.fluke.com/manuals/175_____umeng0100.pdf
Sorry to be the bearer of bad news, but Fluke products are typically quality test instruments and there might be a possibility that you're still covered under their warranty, so checking with them is the best avenue for getting it back to working condition.
I hope you find this Very Helpful and best regards!
Top Fluke Networks Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Fluke Networks Measuring Tool and Sensor Expert? Answer questions, earn points and help others
