SOURCE: I have the Panasonic dmc-tz1 it keeps saying to
You surelly drop down the camera or you have some sand inside the zoom lenses movement. You need to open the camera, opens the zoom lenns the clean the gear or replace the broken gear inside lenses
SOURCE: PANASONIC LUMIX DMC-TZ1
follow some tips given below:
1.try changing the battery ...
2.just plugin the charger with out battery and then try
3. check whether it is connecting with the pc or not ..
if it is connecting with the pc then there is no firmware problem...
if problem persists then the firmware has got corrupted you must installed with the new firmware
or may be the POWER IC might have gone.....
just contact the nearest service technician......
any doubts reply me
i am always here to assist you
thank you
bye
SOURCE: Lumix DMC-TZ1 Memory Card Error
Try formatting the new card in the camera. Also, download any pics from the old card using a card reader and then, format it in the camera.
SOURCE: What is the highest capacity memory card that I
Assuming you're using SD cards, they top out at 2GB. Cards larger than 2GB are SDHC and they will not work in the DMC-TZ1. So, you may use SD cards up to 2GB in size.
SOURCE: Panasonic dmc-fx12 as a webcam
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FX12K
The above link has a .pdf file downloadable that may tell you how to use your camera as a webcam.
Good luck to you.
