Question about Panasonic Lumix DMC-FZ20 Digital Camera
Plugging in the USB connection between Panasonic Lumix FZ20 and Mac G4 results in immediate computer shutdown. Camera is on and in playback. Battery fully charged. OSX 10.4.11 is installed. Manual insists driver should show up on desktop using OSX after cord plugged in, with no additional software installation. None of the software on CD provided with the camera is OSX. No updated drivers (supposedly not needed) found.
Posted by guystr09 on
Anonymous
    Master:
  • 411 Answers
The usb socket of the camera,must be chaqued,if needs replace it....conection failure.
Posted on Mar 07, 2010
2answers
The photos aren't downloading from my camera - a Panasonic Lumix DMC-TZ3. Indeed, my computer (a MAC) doesn't even recognize that the camera is connected. Please can you help as my holiday photos are stuck...
HI,
Please reinstall your camera drivers.Uninstall it first from the control panel add/remove programs and then with the disc provided to you install the drivers.
How do I connect the Panasonic Lumix FZ20 Digital Camera to my PC
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Windows Photo Gallery or any other photo cataloging program.
My panasonic lumix fz20 won,t connect to my pc. when i connect it to the usb it stops my mouse from working.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
I have a panasonic Lumix dmc fz20....which I absolutely love....but I can not download picture from my camera to my computer from my sd carddo not have software lost cd during movehave new computer...can...
I have the same camera but its lens zoom assembly is broken and now does 'nt work. However, I never needed any cd to down load from sd card to either Laptop or Tv. Lap top has the sd card slot failing which you could use an sd card adapter(can give it to you free if you are in delhi) with usb connector to connect to your computer which may help in downloading.Alternatively, a a usb cable connector from camera to computer should also do.All the [email protected] [email protected]
Lumix DMC-FZ20 Digital Camera: download software for computer photo transfer...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Single exposure, double download????
From your description, your problem may be using the same card in two different cameras. You will need to format the card in the Lumix to get it to work properly. This will erase the card so download any important pics first. Then, stop trading cards between cameras.
How to charge the camera
Hope you got the battery charger with the camera kit. Use it to charge the battery.
Can i use my panasonic DMC-FZ20 as my capturing device or webcam on my pc???
yes,his til backside usb pin are connect and then connect to pc then after instoll automatic process then you connect and use capturing device.
Driver for Panasonic DMC-FZ20
the driver should/ is included in the cd...it has a software compatible to windows operating systems...it also features USB drivers for both mac and win...
Thanks!
Panasonic Lumix DMC-FZ20 Digital Camera Logo
Top Panasonic Cameras Experts
Ekse
ENFORCER
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
