Nikon D100 Digital Camera Logo
Anonymous Posted on Mar 07, 2010
Error r06 in viewfinder when focus is locked. I origionally had r03 because I had the long expoure noise reduction set to "on". I changed that setting to "Off" and now I have r06 ??? Any help would be greatly appreciated Thanks, Harry
  • Anonymous Mar 07, 2010
    This problem still persists. If I shoot repeatedly, (It only allows a very slow shutter response), the r# does go down. However, it jumps right back to r06 quickly. The shutter only fires at about 1/2 second, no matter what I set it on. I'm afraid that this might be a problem that only Nikon will have to address.
Glyn Kendall
Level 2:
  • Expert 146 Answers
  • Posted on Mar 07, 2010
Glyn Kendall
Expert
Level 2:
Answers
146
Questions
0
Helped
53119
Points
435
This is not an error, this is telling you how many more continuous shots you can take before the buffer fills up and you have to wait a while for it to empty.
Take a few quick shots and you will see it go down.
It means R(emaining) shots.
I used to worry about this.
Hope this helps.
Testimonial: "My problem was with the shutter firing at about 1/2 sec no matter what I set it at. Now, the shutter is firing fine, but I still have the r06. Thanks"
I cannot get my canon T6 to focus. Even the exposure bar in the viewfinder is out of focus. I know it's a setting, but I don't know which one because my instructor changed it
Hmmm... if the viewfinder exposure bar is also out of focus, I think the problem might be the manual focus for the viewfinder itself. Usually cameras have little thumbscrew somewhere near the viewfinder. It's there to accommodate differences in some peoples vision (do they have their glasses on or not ?). Yup... that's my bet. Give it a go. Is it on the top, right of the viewfinder?
/The GreyOne
We are trying to set up some product photos with a white background and 2 x 1000W soft boxes The background is coming out grey not white How do we set up to give us a bright white background and clear...
1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken •
Flash card error appears on the screen and stops the camera from shooting
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory card
My d100 will auto focus but will not shoot
Having received no response in over a month, I assume this is no longer a problem.
1helpful
Will give correct expoures in ttl
Hard to tell what might be going on without knowing what camera you are using or what shooting mode the camera is in.
What I do is set my camera to Manual. Then set the shutter speed for 1/60th a second. Try a shot with the SB-800 attached - firing directly at a subject that is about 6 feet away and check your image.
To expand the range of the flash, you can change the ISO setting. Adjusting from ISO 200 to 800 will allow you to expose more background. Depending on the camera you are using, this may also introduce more noise in the image.
3helpful
2answers
Unable to focus image in viewfinder
There is a little wheel nest to the viewfinder on the camera. It is called something like dioptric focus (forgive me I am going off of what I heard pronounced) and it allows you to manually set the focus to your eyesight. Just adjust the wheel while looking through the viewfinder and you should be set.
1helpful
Nikon D80 Camera
During shooting, or when the shutter-release button is pressed halfway, the number of images that can be stored in the memory buffer at current settings is shown on the exposure-count displays in the control panel and viewfinder. "r06" indicates that six images can fit in the camera's buffer, "r08" would indicate eight frames. Any other number could be displayed as well. Burst mode is used when you want to hold down the shutter button and continuously shoot. You are probably shooting in burst mode and your buffer is full, set the camera to single shot and see if that helps.
3answers
Error Code
No, it's not an error. What this display indicates, is the availability of the total number of photos you want to take. If the display says, "r06", then you are in JPEG Mode. If it says "r03", then you are either 1) in RAW Mode, or 2) have your Noise Reduction on (see FAQ #2). As you take a few photos in succession, you will notice the indicator drops by how many photos you took.
5helpful
Nikon d100 error code r03
If you have a "r03" display, then you need to go into your CSM Menu, and scroll down to CSM #4, and turn LONG EXP. NR to "OFF". When you are in Noise Reduction Mode, your D100 buffer is literally cut in half.
3helpful
Digital SLR "r06" (or other number) in LCD display
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
