Our 52" RCA TV stopped working. It just suddenly turned off when watching. My husband took off the back panel to look inside and saw a blown fuse. Could that be the problem?
It could be the problem or just a symptom of the problem. If the fuse is replaced and blows, then it's something else. Hopefully it's just the fuse. Good luck!
Did you try another channel? Did you try playing music from another source like dvd player, I pod through it?. This is called elimination process that will bring you down to the culprit. I will be more than willing to help you from here after I here from you.
Hello again you need to Rate my solution other wise they are not going to pay me! since i did give you correct answer to fixing your TV ThanK You Replace 3 capacitors cp150 2200uf use 25v and cp114 cp120 220uf 35v.
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
the arcing sound is some kind of high voltage leak, which will shut down the tv. pull the speaker grill off and the access board, look at the 3 picture tubes, turn the set on you will see where the leak is, it's usually the high voltage splitter, which has a high voltage wire going into it and 3 high voltage wires coming out going to the picture tubes, if it arcs from the splitter you need to change it, if it arcs from one of the picture tube wires you need to pull the tube out and fix the high voltage leak, and possibly a cooling fluid leak caused it, not an easy reapir, you probably need a repairman.
the chasis number of your tv is eithor itc222 or itc221 the deflection board causes most of the problems part number 258762 part discontinued but you can contact eithor pts electronics or tristate module to see if they can fix yours
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
replacement of the color wheel is an option.. as a technician i dont find replacement all that difficult. finding one too replace it with is the most problem...
