Question about Dell Inspiron 1525 Laptop
My Dell inspiron 1525 frequently has a sort of freeze up when no keys will work .hovering over things causes them to highlight and I need to hit the escape key many times to unfreeze it.
Posted by lfox18 on
Anonymous
    New Friend:
  • 77 Answers
Control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Posted on Apr 06, 2010
Dell inspiron 1525 has good wireless signal but i can't get on the internet any more. At first you could type in google,and it would work. Then you type in yahoo it would not go to that site. N
go to your taskbar icon for your wireless and right click and click on open network and sharing center.click on manage wireless networks. delete all your networks. close the sharing center and then press the windows key and the r key at the same time. type cmd. in the black box type ipconfig /flushdns hit enter. type exit. go back to your taskbar icon and left click. click the connection you're trying to connect to and hit connect. enter the security password, and try again.. this should fix everything. good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jan 31, 2012 | Dell Inspiron 1525 Notebook
My dell inspiron 1525 often slows down
To speed up the computer we need to follow these steps this will run your computer operation much faster.
Click the start menu button and select run or search command box type in %temp% and then press enter you will see a box with lots of files single click on one of the file or folder then press the control + A key it will be all selected or highlighted, now you can press shift + delete key on the keyboard this will remove all temp files which is not necessary for the computer.
Type in the run or search box prefetch hit enter and follow the same process as the first one after that open control panel and select add/remove program it will show all the installed softwares in xp and in vista/win7 open programs and features icon once you see the unwanted list of installed programs highlight and remove it one by one, you need to identify the once which you do not require and then remove it by simply highlighting and hitting the change/remove button.
Run msconfig in the run box or the search box it will open a window click on the startup tab and deselect the one's which you dont require while system boots.
Nov 14, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 cannot connect and says I need to turn on wireless capability using function key combination - what is it?
The wireless radio combination should be the Fn+F2 keys to activate it. That is to hold down Fn and hit the F2 key.
Regards.
Nov 09, 2009 | Dell Inspiron 1525 Notebook
Inspiron 1545 keyboard erratic behavior
Could be a keyboard problem ,when it happens press the ESC key and see if it stops.
If you can try with an external keyboard then you can test if the current keyboard is failing.
Nov 02, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
My dell inspiron 1525 continuously keeps locking up. The screen just freezes up. I am unable to bring up task manager or hit escape. The only thing I can do is shut the power down / bring back up. This is...
Try this steps:
Turn off your laptop.
Power own your laptop then press release the F8 key until this option will popup.
Select Safe Mode.
Wait until Windows succesfully boots up using safe mode.
If you can succesfully log-on on your Safe Mode.
Press Windows Key + R
The run window pops up type MSCONFIG
Click Start Up as show below
Uncheck all check Items and click OK
Reboot your laptop and boot windows in normal mode...
Hope this helps...
Oct 21, 2009 | Dell Inspiron 1525 Laptop
I have an inspiron 1525 and almost as soon as i
If you have unresolved issues with Dell systems, you should contact Dell here:
http://support.dell.com/support/topics/global.aspx/support/dellcare/outstanding_issues?c=us&cs=2684&l=en&s=pub
Technical Support issues option and see what you can get done to resolve your issue.
Oct 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
My Dell inspiron 1525 keeps freezing on the screensaver.
Try a differaent screen saver. I had the same problem used a screensaver from the net caused that. used one from windows problem gone.
Jul 24, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Dell 1525 laptop keeps freezing
i am suspesioning on Rams. maybe overheating also does that.
May 30, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron 1525 Laptop Logo
209 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
