Cars & Trucks Logo
Anonymous Posted on Mar 06, 2010
Can you help me dis-assemble my front bumper honda odyssey 1999 ?
Can you help me dis-assemble my front bumper?
  • Anonymous Mar 07, 2010
    its a 1999 year model honda odyssey.
  • Greg Bernett
    Greg Bernett May 11, 2010
    Sure, but what year is your Odessey?
Greg Bernett
Level 3:
  • Honda Master 2,993 Answers
  • Posted on Mar 07, 2010
Greg Bernett
Honda Master
Level 3:
Answers
2993
Questions
Helped
2783109
Points
13428
Front
  1. Note the radio security code, then disconnect the negative battery cable.
  2. Remove the bolt from the lower part of the bumper just in front of the wheel opening, and remove the self-tapping screw from the rear most portion of the bumper at the forward portion of the front wheel well.
  3. On V6 Odyssey models, perform the following:
    • Remove the grille.
    • Remove the pins and clips from the lower front of the bumper.
  4. On 4-cylinder Odyssey models, remove the bolts from the left and right side lower brackets for the bumper at the ends of the lower air intake.
  5. Pull the ends of the bumper outward.
  6. Have an assistant help guide the bumper up and away from the vehicle.
  7. Installation is the reverse of the removal procedure.
2answers
How do you remove the front bumper to get to the fog lights on a Honda Odyssey 2006?
you need a haynes repair manual look in the body chapter.reason you need a repair manual because you need to see how remove front portion of fender well liner to under the front bumper fascia to remove fog lights.manual will keep you from damaging your car.
2002 Honda Odyssey van, the windshield washer doesn't squirt fluid or wipe the wipers, though the windshield wipers work separately . . . . how to fix?
Sounds like you may need to change the washer fluid pump. They do go bad. It's located inside the washer fluid reservoir, which is in the front of the passenger's side wheel well, behind the front bumper.
How much to replace the front bumper on a 2009 Honda Odyssey. There was a minor bump - You can not even see any indentation just the slight crack in the lower bumper. This bump caused the lower bumper to...
Approx £300 from honda, but you can get a cheaper part that looks just the same for about £190 if you can find a salvage yard you might get a genuine honda one the same colour as your car for about £100
Replace fog light bulb for 2006 Honda Odyssey
Touring Model
Use a wrench to remove the mounting bolt from the underbody through the hole in the splash shield.
Remove the fog light assembly from the bumper by pulling its inner edge first, then the whole assembly out of the bumper.
Remove the electrical connector from the bulb by pushing on the tab and pulling the connector down.
Remove the bulb from the fog light assembly by turning it one quarter turn counterclockwise.
Push the electrical connector onto the new bulb.
Turn on the fog lights to test the new bulb.
Reinstall the fog light assembly into the bumper. Tighten the mounting bolt.
Insert the new bulb into the assembly and turn it one-quarter turn clockwise to lock it in place.
Hope this helps you.
How do I replace my front HEADLIGHT ASSEMBLY on a 2008 Honda Odyssey,
Open the bonnet temove the bulkhead cover drop the front bumper (its not that hard). Now remove the wires from the headlight (unplug them) remove the screws that hold the light in and reinstall the other light the same way. (Remember that the NTSB requires the headlights be aimed at a designated hight)
3helpful
Remove right front fender on 2005 odyssey
NO 2 BOLTS ON TOP OF FENDER UNDER HOOD 1 BOLT BEHIND PLASTIC TRIM BY MIRROR PULL THIS PIECE BACK TOWARDS MIRROR OR IT WILL BREAK TABS OFF 1 BOLT UNDER ROCKER TRIM 1 SCREW INTO ROCKER AND 1 SCREW BEHIND PLASTIC SHROUD GOING INTO BUMPER FROM UNDER NEATH PULL BUMPER BACK SLIGHTY AND YOU WILL SEE A WHITE PLASTIC CLIP PULL BACK AND BEHIND THIS IS A BOLT REMOVE HEADLIGHT CLIP FROM FENDER AND LOSEN BOLT BY HINGE NOW FENDER SHOULD COME RIGHT OFF BOOK IS 2 HOURS TAKES 1 HOUR TO REMOVE BUT GOES ON IN ABOUT 30 NINUTES
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
