Question about Whirlpool RBD305PD Electric Double Oven
Oven does not work,no display.
I just bought a house with a double oven model RBD305. The appliance is nearly new but the display does not show anything. The lights work, the power is on and checked at 220V, some buttons beep. The display shows no time or error messages. Any ideas?
Anonymous
  • 161 Answers
The display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Posted on Mar 06, 2010
Testimonial: "It appears as though this will require a repair person with all the parts. Nothing I can do on my own. Thank you for the input."
Whirlpool double oven display reads E6 F2
I have a Whirlpool RBD275PRT00 that showed the same codes. it would allow me to cancel and work for a few more days until the display finally went blank and after a few days of being blank displayed the codes again. I ordered a New Electronic control board from Sears W10340941 for 189 dollars just recently, when I just looked for this part for your model it's that same number but now listed for 254. There are services that will repair your board for a little less but it will not be a new board. it's still much cheaper that a new oven.
Dec 02, 2013 | Whirlpool GBD307PRS Stainless Steel...
Unable to remove door. picture does not look like the rbd305 we have
These ovens require that you remove the whole side covering to get to the hinges and door hardware.
Oct 21, 2013 | Whirlpool RBD305PD Electric Double Oven
Display went out on my whirlpool RBD305 oven and then it stopped working
You will need to replace the control board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 20, 2012 | Whirlpool RBD305PD Electric Double Oven
What are the electrical specs for model RBD305 Double Oven
All the information for that is usually located on the tag where the model and serial number are at. Electrical specs are 220v a/c 60hz. I can't recall the amperage. If you don't have the owners manual you can go to www.apdepot.com and get one
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 27, 2012 | Whirlpool RBD305PD Electric Double Oven
My thermador double oven display is note openly connected. How do I fix it?
This board set can also be rebuilt at www.fixyourboard.com. Dim display is a common failure that can be repaired reliably at a fraction of the new board cost. Here are the relevant partnumbers :
35-00-760, 12001691, 492071, 14-38-901, 492069, 492067
1065923121 , 1065923160 , 1065923161 , 1065923200 , 1066025120 , 1066025150 , 1066025151 , 1066025160 , 1066025201 , SCD272T , SCD302T , SCE30500W , SCE30600B , SCE70600B , SCE70600W , SC272T , SC301T , SC302T , SMWS72YP AFTER S/N 8204 , SMW272B , SMW272P , SMW272S , SMW272W , SMW272YB AFTER S/N 8204 , SMW272YS AFTER S/N 8204 , SMW272YW AFTER S/N 8204 , SMW272ZS AFTER S/N 8204 , SM272B , SM272S , SM272W , SM272YB AFTER S/N 8204 , SM272YS AFTER S/N 8204 , SM272YW AFTER S/N 8204 , SM272ZS AFTER S/N 8204 , SVD48600B , SVD48600PF , SVD48600PG , SVD48600PK , SVD48600PR , SVD48600PT , S272T , S301T , S302T
Feb 02, 2012 | Thermador SC302T Electric Double Oven
Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
asplogo.jpg?ver=23
appliance parts, help & more
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD305PD Electric Double Oven Logo
1,397 people viewed this question
Top Whirlpool Ovens Experts
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
