Question about E-Machines (T2958) PC Desktop
I have a T2958 and toof the face off. Can you
I have a T2958 and took the face off to replace the dvd drive. Can you tell me the sequence for the 3 sets of wires to go back on? I thought it was one plug but is actually 3. Power, switch, and hard drive indicator.
Posted by bbessette3 on
joecoolvette
  • E-Machines Master
  • 5,660 Answers
EMachines doesn't give out this kind of info, and I don't have one in the shop.
eMachines also had the habit, of using a few different manufacturer's of motherboards. Intel, TriGem, MSI, Asus,and FIC to name five.
Plus eMachines would use whatever was available at THAT moment, when they were producing that particular model line. (Not stating the T2958 specifically. Whatever model line they were making at the time)
Plus at the time the T2958 was made, Gateway had bought out eMachines. (eMachines later bought themselves back)
However all is not lost here. At the time the T2958 was made the motherboards were manufactured by Intel.
The Intel D845GVSR
Uses the Intel D845GV MCH, and the Intel ICH4 southbridge chipset
(MCH. Memory Controller Hub. Intel's naming for their Northbridge chipset)
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2958
You are looking to see where the wires go, on the Front Panel header of the motherboard, from the Front Panel of your computer.
(Front Panel header on a motherboard, is essentially where the wires go that come from the Front Panel of the computer. When referring to a connector on a motherboard, a connector is a Header.
The Power On switch wires, HDD Activity Lamp, Reset switch, {If used}, and Power On Lamp, are located in the Front Panel, for your computer)
{Front Panel = 'Face'}
As stated, eMachines does not give out this info.
I just need your patience, and your eyes. I need you to compare a photo of a motherboard to yours.
When you open your computer case, the side cover should come off of the Left side.
The back of the computer will be to the Left, the front to the right.
The Processor will be at the top of the motherboard, and the Ram Memory slots will be to the right.
Observe the motherboard photo at the top of this page,
http://www.dexplor.com/phpBB2/viewtopic.php?f=13&t=7747553&sid=8fa7e78bbadfbd6fde083b28641248cc
Orient in your mind so that the motherboard in the photo will have the Processor to the top, and the Ram Memory slots to the right.
Should you have no idea of what I'm referring to here, please come back, and state so in a Comment.
The Front Panel header is composed of three individual headers, (Connectors) for this motherboard.
J9F2, J9G1, and J8H3
The J9F2 is for the USB ports used in the Front Panel. We won't be concerning ourselves with this header.
J8H3 is located to Right side of the CMOS battery. It has two pins sticking up.
This is where the Power On LED light plugs into, IF, the Power On LED light has Two wires, and the light is one solid color when lit up.
J9G1 is located below the CMOS battery, and is located on the bottom edge of the motherboard.
There are two rows of pins sticking up.
The rows are parallel to the edge of the motherboard.
The top row has 4 pins.
The bottom row next to the edge of the motherboard has 5 pins.
The pins are numbered from the Left, going to the Right. There MAY be a number 1, or 2, stamped on the motherboard.
I wouldn't count on it.
The top row of pins, going from the Left towards the Right are,
2, 4, 6, and 8.
The bottom row of pins going from the Left towards the Right are,
1, 3, 5, 7, and 9
There is no Pin 10.
1) Pins 1 and 3 are for the Harddrive Activity light. (HDD)
2) Pins 2 and 4 are used for a Power On LED also.
3) Pins 6 and 8 are for the Power On switch
Should you have more questions concerning this, please state so in a Comment.
Posted on Mar 07, 2010
  • joecoolvette
    joecoolvette Mar 10, 2010
    Thank you for the rating bbessette3, Most Appreciated!
My xbox will not read my games or movies and it will keep saying open tray
Clear the system cache:
1. On the console, go to My Xbox, and then select System Settings.
2. Select Memory.
3. Highlight any storage device, and then press Y on your controller.
4. Select Clear System Cache. If Clear System Cache is not available, use the following controller button sequence to clear the system cache: X, X, left bumper,right bumper, X, X Note If you don't see a system maintenance prompt on the screen, try pressing the button sequence again.
Try playing discs without the hard drive in:
1. Turn off your console.
2. Locate the hard drive on your console.
Press the release button on the hard drive and lift the hard drive from the console.
Turn on your console.
3. Try to play a game disc.
If this resolves the problem, you will need to replace the hard drive.If not, do the same thing for your memory units. If it works without them,they may be bad.
Thank you !!
Jun 23, 2010 | Microsoft Xbox 360 Console
I have a pioneer avh-p3200dvd the green wire is connected to the park brake but dvd has not playback
Because there is a sequence you have to use before the picture can show up. You will have to engage then disengage maybe two or three times and wait 1 to 3 secs between intervals. Experiment with different combo's. When the pic comes up you have found the right sequence. It should also tell you in the radio manual the sequence of events you have to do before you see the pic. They do this to prevent you from watching a video while driving your car. SAFETY FEATURE.
Apr 08, 2010 | Pioneer AVH-P6600DVD Car DVD Player
I want to to return my emachine to factory settings..Have the T2958 ver 1.1 restore dvd. Won't auto run- I click on the icon and its just text. Is that a command prompt?
you will need to restart the computer and boot off the restore dvd.
This is done outside of the operating system.
When computer is first turned on keep hitting f10 untill you get the boot menu up, choose the dvd drive and it should work for you.
Mar 11, 2010 | E-Machines (T2958) PC Desktop
DVD wont initialize, it will not see that a disk has been inserted, no matter what you insert, blank recodable disk or a pre-recorded movie/disk. Has the drive gone bad? is there a fix or a replacement...
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Feb 27, 2010 | JVC SR-MV40U VCR
Panasonic dvd-s54 unlock code to make it play region-free
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__uji8
Dec 27, 2009 | Panasonic DVD-S54 DVD Player
Dvd player does not play
Does it read other CD's. If yes:
I would start off by thinking you just don't have software (codecs) to play the DVD
Try downloading VLC player. Look it up in google.
Jul 16, 2009 | E-Machines (T2958) PC Desktop
Update
Since the T2958 doesn't come with a DVD drive capable of burning you would have to buy another one capable of burning and install this into your machine.
So the answer is yes, you can upgrade your drive.
Apr 08, 2009 | E-Machines (T2958) PC Desktop
Dell Dimension 5510
Normally you would set it up to boot from:
1. CD/DVD drive
2. Hard Drives
There may also be a floppy drive to add in whereever you want it.
This problem sound like some kind of drive controller or the drives are not being recognized in BIOS...check and make sure you see the hard drives when setting the boot order.
Mar 15, 2009 | Dell Dimension E521 PC Desktop
Code multiregion
here is one way:
and here is a forum whre you can get more information
http://www.avforums.com/forums/showthread.php?s=df1223ea6de85d218b01e9719ddec248&t=368649
Dec 18, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
DVD stuck
Replace the drivebay of the Bose AV3-2-1 If the drive sticks, or does not open, or If you receive an error of NO DISK, or any indicator that the disk is not properly recognized clean the lens and if still doesn?t work then the DVD drive is bad. You can actually use one for a desktop PC with a few part swappings. Check that the drive is a Toshiba SD-M1612 it is printed at the bottom of the drive bay. To use this SD-M1612 as a replacement you will simply have to swap three external parts. Remove the 3 parts from the bad Bose drive bay: Remove the 4 bottom bolts, lift cover, if the DVD bay door is locked then insert a paperclip into small hole in the front. Slide DVD tray out and remove the PC style DVD ROM tray facing. 2 clips hold it on pry them out and slide the facing up and off. Now remove the face of the drive bay. It has several clips. Save these three components (top cover, face, and tray facing) to add to the new Toshiba SD-M1612 DVD bay. Remove the old and installation is the reversed procedure above. also remove the small clear LED bezel from the new drive before adding the face. It works fantastic.
Mar 26, 2007 | Bose 3·2·1 II System
E-Machines (T2958) PC Desktop Logo
244 people viewed this question
Top E-Machines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
