My sony nwz b133f is detected as mtp player but not as walkman . previusly it use to get displayed in removable devises as walkman as soon as i connect . i recently formatted my system and i am facing the problem please help me out
If your PC has windows XP sp2 or later and Windows Media Player 11, try to do these steps:
1. Connect the player to the computer. 2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed. 3. Select Hardware tab, and open Device manager. 4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX. 5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed. 6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next. 7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method. 8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option. 9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed. 10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
If your PC has windows xp sp2 or later and Windows Media Player 11and f you have problem with your device follow this steps: 1. Connect the player to the computer. 2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed. 3. Select Hardware tab, and open Device manager. 4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX. 5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed. 6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next. 7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method. 8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option. 9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed. 10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
This advice can help if your player can work correctly. Thanks. gylacz
I had the same problem but i solved it. Follow the folliwing steps.
1- Download firmware nwz-b133f (firmware nwz-b130 V-1.01)
2- Download firmware nwz-b103 (firmware nwz-b100 V-1.3)
3- First execute firmware nwz-b100 , connect your walkman when the programm asks: please connect device. Then the program ask format your device you will loose all the data , click accept.
4- Don´t disconnect your device , wait until format and dataload are finished. This is necesary because firmware nwz-b130 doesn´t do the format.
5- Disconnect your walkman and you will see it doesn´t start (logical it ain´t his firmware)
6- Now execute firmware nwz-b130 , connect your walkman when the programm asks: please connect device. Don´t disconnect your walkman wait until program ends.
7- When finished disconnect your walkman the save way.
8- Ready like new.
Greetings Quicktronics here from Mexico.
Yo tenia este problema y esta solucionada. Sigue los siguientes pasos.
1- Baja firmware nwz-b133f (firmware nwz-b130 v-1.01)
2- Baja firmware nwz-b103 (firmware nwz-b100 v-1.3)
3- Primero ejecutar firmware nwz-b100 , conecta tu walkman
cuando pida conectar por favor el dispositivo luego pida formatear
el dispositivo vas a perder toda la informacion has click en
aceptar.
4- No desconectas tu walkman espere hasta que formatea
todo y carga todas su datos , este era necesario para el puro
formato porque el firmware nwz-b130 no lo hace.
5- Desconectas tu walkman y vas a ver que no enciende (logico no
es su firmware)
6- Ahora ejecutar firmware nwz-b130 , conecta tu walkman cuando pida conectar por favor el dispositivo , no desconectas tu
walkman espere hasta que carga todas su datos.
7- Cuando termina desconecta tu walkman de manera segura.
8- Listo como nuevo.
Avg scans a portable drive every time you access it . If you still feel that your player is infected , try Avast or the lesser known Removeit Pro (antivirus softwares )
I bought a new Sony NWZ-B133F/BCE Walkman. When I plugged it to the USB
the drivers got properly installed, but the player does not show as a
removable device or any other device in My Computer. just follow...be sure your player is connected to pc
go to my computer right click>>properties> IN HARDWARE TAB
select device manager>portable audio>right click select update
drivers>click next>tick the option let me choose driver for this
device>next choose usb mass storage driver from two options click
next....
AND U R DONE....
