APC Back UPS 650 (APWBK650MC) UPS System Logo
Posted on Mar 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
APC Back-UPS PRO 650 Front indiactor LED's and invertor not working. when power button pressed there is a beep sound.there is charging voltage when the AC voltage is connected.
electronic & computer repair& servicre
Level 3:
  • Master 12,061 Answers
  • Posted on Mar 06, 2010
Master
Level 3:
Answers
12061
Questions
0
Helped
4005227
Points
36390
Check the batteries first
2answers
APC BK650EI 650 VA 400 Watts (1) IEC 320 C13 (Surge Protection) (3) IEC 320 C13 (Battery Backup) Outlets Back-UPS CS 650 USB/Serial. It blinks random orange LED.
I say yes he manual shows ,setting sensitivity here.
the sound like charger fail. Inside.
inverter works, did you let it charge overnight first.
and disable the beeper if annoying.
is AC line voltage low? that too can beep.
is this USA model 120vac or outside USA>
also if the UPS is for another country that will be bad.
650EI , is not the E means European version"??? why skip country.
>? and matters huge that.
EI is 230vac version, and will be wrong used in 240vac countries and worse.
yellow led only blink is low line AC as the manual tells
my guess you bought the wrong UPS?>
v2 docs but not told version
page 2.
https://download.schneider-electric.com/files?p_Doc_Ref=SPD_AHUG_990-9237_EN&p_enDocType=Quick+start+guide&p_File_Name=BU+UM+990-9237B+MN01+EN.pdf
Apc 650 back-ups does not boot
try turning on the power connection
I want to use the apc 650 pro to run on my 900 watt generator.I will be pulling about 400 watts,will this smooth out the voltage from my generator to my radio? Is there anything I must do to use the apc in...
the battery back-up will smooth out the voltage, You will definitely need a battery in or else it will beep nonstop and drive you batty! the APC should have surge protected outlets already built into it. And since you will be using it outside of a computer environment, im guessing on a worksite, there will be nothing extra you need to do besides plugging it in. I would suggest plugging it into a stable voltage for the first hour or so to allow it to charge the battery.
1helpful
SO bad, and a bad response... I have 2 UPCs one started beeping for no reason, and will not stop...even when plugged into the wall with the battery disconnected... The other one is still silent. SO the...
These beep error codes may help you.
1. Four beeps every 30 seconds (On Battery LEDwill be illuminated)
This alarm indicates that the Battery Power Suppliedoutlets are now supplying battery power as opposed to power from the utility.If the UPS determines that the input utility power is unsafe for your computerequipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Battery condition hasbeen reached and that the UPS will soon shutdown. Once the UPS transfers to OnBattery operation, it can only stay on battery for a limited amount of time.The UPS will sound this alarm about two minutes before the batteries aretotally exhausted. Once exhausted, the UPS will shutdown and turn off itsoutput power to your equipment. If you hear this tone you should immediatelyshutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPSOFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overloadcondition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detectedwhile the unit was on-battery operation. This tone will continue to sound untilthe unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-powered outletsare overloaded.
6. Continuous Tone (On Line and On Battery LEDsflashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault hasoccurred.
3helpful
2answers
Any schematics available for a APC Back-UPS Pro 650PNP? I installed a new battery (yes correct polarity) and smelled a little smoke. It was unplugged during the battery swap. I took the cover off but...
hi, i don't have the schematic but, i think if you connected the batteries okay and had switched off the machine then it should work. when switching on there are two sounds that come, first its a beep, if you release the ON SWITCH the UPS will just do a self test then shutdown. to switch ON the UPS completely don't release the on button until you hear a second beep, if you release the ON switch when this beep is on, then the UPS will be ON completely.
After a power outage my apc has this clicking sound. every 4 seconds or so it sounds like it clicks and then a slightly different click 4 seconds later. However, when everything is powered up it doesn't...
I found this on the APC website;
Question: What would cause a Back-UPS Pro, a Back-UPS Pro USB, a Back-UPS RS, a Back-UPS CS, a Back-UPS LS, or A Back-UPS XS to beep once every 5 seconds with no output power?
Answer: One beep every 5 seconds is an indication that the UPS has entered what is called "Low Voltage Sleepmode".
The Back-UPS product has transferred to battery power due to a low voltage condition at the wall. The Back-UPS has remained Onbattery until its runtime was totally exhausted, however, there was still enough voltage present at the wall to trickle charge the battery.
This is considered to be a normal operating state. When the voltage returns to normal the Back-UPS will wake up and restore power to the battery outlets.
Back ups battery rpo1100 APC disconnects the Dell PC power button
try plugging the pc directly into the wall...if it works the UPS is defective.  You can order new batteries for the UPS online.
Battery Planet.com
My APC keeps beeping.
possibly..you have unpluged or dislodge you power cable from the outlet or from the power plug shuye at the back of your ups.. double check all the plug and re plug all your power cables !!!! make sure they are tightly pluged in and firm in their outlets..
Top APC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
