Dell Inspiron 4100 Notebook Logo
Posted on Mar 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Device manager shows problem with cdrom drive says Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Anonymous
Level 2:
Guru:
  • Expert 266 Answers
  • Posted on Mar 06, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
266
Questions
Helped
65849
Points
854
Download microsoft fixit from http://www.ziddu.com/download/6528022/MicrosoftFixit50027.msi.html and install in your system, then restart it. now you can see your CD drive working perfectly
Anonymous
Level 3:
  • Dell Master 32,281 Answers
Anonymous
Dell Master
Level 3:
Answers
32281
Questions
Helped
7907854
Points
102259
You need to re-install the CD-ROM driver.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
  • Anonymous Mar 06, 2010
    Why was my solution not helpful?
    Did you try installing the driver from Dell?
    Unless you know what you are doing changing the incorrect registery item can do more damage to your laptop.
    Thank you for using FixYa, it is obvious you no longer need my help.
ATAPI DVD A DH168BSH configuration incomplete or damaged
Try uninstalling the DVD drive in the Device Manager in the Control Panel, then do a graceful shutdown of the PC. Power the PC back on and see if it finds "new hardware" and installs the driver. I take that you have an Acer Aspire PC.
2answers
My cd driver isnt working and device manager says: Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) have an hp probook...
Most cd/dvd's don;t use a driver they rely on a atapi common driver. Usually when you get problems it means the drive itself is the issue. For now what I would try is simply to go under /control panel hardware manager and delete the drive then reboot. Windows will detect the drive and should re-install the device information and correct the registry.
2answers
Drive will not work. Device Manager tells me Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
simply restore your system within latest checkpoint created by windows or manually
if still it shows error then press restart button and press F2 to launch BIOS detect your cd drive dvd and press F10 to save changes
When my Brother HL-2140 Laser printer (USB port) all of a sudden stopped printing (or prints blank pages), I went to Device Manager to check on my hardware status. Under DV/CD-ROM drives, TSSTcorp CDDVDW...
Seems like the registry for your Dvd-Rom is corrupted. Try disabling and uninstalling the driver, then enable and wait for windows to clean install its driver.
2answers
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Revert to the most recent successful registry configuration
This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP
hope this helps
please leave feedback
thanks
Robb
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP.
Good Luck .. !!
15helpful
3answers
Pioneer DVDRW DR-KD08HB not working on HP Pavilion Solved the problem once from fixya and now the problem returned. Anyone??
You should really give more detail on the issue for people to solve the problem quicker. If you can't see the dirve on your drive list but it show up under device manager and getting error 39 you can try the following link.
http://msbin.com/kb/entry/53/
Code 19 error on ibm windows XP PC...neither the DVD or Cd drive are recognized or able to perform any functions.
try to uninstall the cd rom.... then restart your computer
CD Rom and DVD Rom won't work
you need to delete lower and upper filters from registry to fix the problem instructions CLICK HERE
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
