Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
Posted on Mar 06, 2010
How do i put it on discover mode - Mad Catz PS3 Bluetooth® Headset Wireless Headset
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Mar 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
1017
Points
13
Press and hold the button 10 sec, lighting? then search in phone.
Dell searches anbd never discovers targus speaker
Make sure to put the Targus Blutooth speaker in discover mode... You need Blutooth activated on your Dell as well. Otherwise, go to the Dell website and start a chat or go to the Tagus web site and chat with them.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
tip
How to put most Bluetooth headsets into Pairing Mode?
There are two main ways to put your Bluetooth Headset into Pairing/Discovery mode:
1. For devices that have a Power Button
Start with the headset in the OFF state, then hold the power/action button until it goes into pairing mode (about 3-5 seconds). When in pairing mode, the light should be flashing red and blue or have a steady blue light, in most cases.
Then you can discover it with your phone or PC.
2. For device that have an On/Off SWITCH
Start with the headset in the OFF state, then hold the call/action button while you turn the headset ON. The headset should now flashing red and blue or have a steady blue light, in most cases.
If you forgot the pairing code, refer here:
http://www.fixya.com/support/r5008953-pin_codes_most_bluetooth_headsets
If you need a copy of your manual, refer here:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
on Jun 02, 2010 • Radio Communications
How to connect bluetooth headset to nokia 2700 classic?
put the headset in detectable mode, put the phone in pairing mode and the two should discover each other and should just connect.
21helpful
How do I put it in discover mode?
How to Pair Cardo S-800
1.Turn on your phone and turn ON its Bluetooth function.
2.Make sure the headset is turned OFF, then press and hold the Power Button for approximately 8 seconds until the LED status indicator begins alternating blue and red, indicating that the headset is in Pairing Mode.
3.Set the phone to search for Bluetooth devices by following the instructions in the phone’s user guide. This is usually found in the phone’s Bluetooth menu and may be referred to as “discover” or “add” a device. (Settings > Connectivity > Bluetooth - turn ON - > Discover Devices)
4.After a few seconds, the phone will list the “Cardo S-800” as a discovered device. Select it from the list and press “oK” or “yes”.
5.When prompted, enter the passkey “0000” (4 zeros) and press “oK” to complete the pairing
6. When the pairing pairing is successful the headset’s LED status indicator will begin flashing.
You should now be able to make and receive calls using your headset. To initially connect the headset to your phone, you may need to tap the CTRL Button once on the headset. iMPortAnt: if pairing is not completed within 2 minutes while the Pairing Mode is activated, the headset will return to Standby mode, flashing blue once every three seconds and you must start the Pairing process again from Step 2 above.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
LG Voyager VX10000 will not discover bluetooth headset. My wifes phone will discover it right away, but the voyager never discovers it. What is wrong? How do I fix it?
only one bluetooth headset right?
make sure its not paired with her phone first. put it back into pairing mode and try searching for it again.
if this has been done then try searching for a different device to check if your phones bluetooth hardware is at fault.
6helpful
Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
2answers
I cant pair motorola H350 to Voyager
Can you pair the voyager with anything?
Are you putting the bluetooth headset into pair mode correctly?
52helpful
Discovering a Motorola H721 headset on my Iphone
open the boom flip. Press and hold both volume buttons and the call button for more than 10 seconds. The indicator light flashes 3 times and then becomes steady lit. The headset is now in pairing mode.
Phone wont detect bluetooth H700
Mine could be discovered when powered off/ on my cellphone and retried... Sounds like solution to M$ programs, eh? :)
Top Mad Catz Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
