Question about Nikon N60 35mm SLR Camera
I got and fEE... and figuered out it means error!!
I got a Nikon D90 camera for my birthday! The other day I downloaded the pictures to my computer and everything went fine. But later that day I tried to take pictures and it didnt work. So I looked at the small screen on the top left corner of the camera and it said "fEE". And I dont know what I should do. Ples help me. Thanks
Posted by val_angie3 on
  • Tim Cottrell May 11, 2010
    This might be a long shot, but on the lens section of the guide shown below, there is a note : Non-G lenses will have an aperture ring on the base of the lens where it's attached to the camera. Set this this ring to the smallest aperture (largest number), usually in orange and 16, 22 or 32. There usually is a lock to keep this ring set there, since if it comes off that setting you'll get an error message (fEE) from most cameras. Full guide is here:http://www.kenrockwell.com/nikon/d90/use... Hope this helps
Tim Cottrell
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 175 Answers
This might be a long shot, but on the lens section of the guide shown below, it notes ,,,,
Full guide is here:
http://www.kenrockwell.com/nikon/d90/users-guide/index.htm
Hope this helps
Posted on Mar 06, 2010
I am trying to install a program from my disc that was supplied with the camera it keeps saying error. i am now running windows 10 and not vista
You need to go to the camera makers website, (the make which appears to be a secret because you haven't mentioned it :>). Other number 1 tip, ALWAYS include Make and Model.
Google
make model windows 10 software
or
make mode windows 10 drivers
It is all available free online. When you Google, this happens
Nikon ' Download center ' D90
downloadcenter.nikonimglib.com/en/products/9/D90.html
D90. Other products. Manuals. Manuals; Firmware; Software. Download product manuals. Title Language Size. User's Manual English 16.71 MB Download. These Download Terms and Conditions ("Agreement") constitute a legal agreement between you (either an individual or single entity) and Nikon Corporation ("Nikon") ...
Nikon D90 Drivers Download - Update Nikon Software
https://www.solvusoft.com/en/update/drivers/digital-camera/nikon/d90/sub-models/ Manufacturer: Nikon. Hardware Type: Digital Camera. Model: D90. Compatibility: Windows XP, Vista, 7, 8, 10. Downloads: 62,405,424. Download Size: 3.4 MB. Database Update: 11/29/2017. Available Using DriverDoc: Download Now ...
Nikon D90 Software ' Nikon Driver Downloads
www.nikondriver.com/nikon-d90-software/ Apr 21, 2015 - Nikon D90 Digital SLR Camera Software Driver and Firmware (Version A:1.00/B:1.01) update for Microsoft Windows and Macintosh Operating Systems. ... Basic Download and Nikon D90 Installation instructions for Windows and Macintosh: ... Download the software, firmware and drivers to keep your ...
Nikon Transfer 1.5.1 Software Download (Windows)
https://www.nikonimgsupport.com/na/NSG_article?articleNo=000027116&lang... Dec 20, 2016 - Nikon Transfer 1.5.1 Software Download (Windows). What is this? (scroll to bottom for download link). This is the software for Nikon Transfer 1.5.1 (Windows). Introduction. Nikon Transfer is a software application that allows for the simple transfer of images captured with a Nikon digital camera, or images ...
nikon d90 software windows 10 Google Search
Feb 13, 2018 | The Computers & Internet
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 flashed CHR and next time using camera LCD was black/grey with stripes and no pics HELP!!!
The CRH error message means that the lock tab on your memory card is in the locked position. The purpose for the lock switch is to allow you to set your SD card so that you cannot accidently erase your valuable pictures. Remove your SD flash memory card from the camera and hold it in your hand with the label toward you and the angled corner to the upper right. Look on the left edge of the card and you will see a very small slider switch. Make sure the switch is in the fully up position then reinsert it in the D90. If the camera is not generating a false error, your camera should work correctly.
Jun 19, 2011 | Nikon D90 Digital Camera with 18-105mm...
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
Nikon D90 that does not want to shoot pictures
The camera may not be sensing that a lens is attached. Try removing the lens completely and then attaching it again securely.
Jan 17, 2010 | Nikon D90 Digital Camera with 18-200mm...
During using D90 for son's b-day my camera kept freezing up and giving a code of r05 and another code once that I don't remember. Why and what does r05 mean? I even turned the camera off at times but it...
The r05 is not an error. It's simply telling you that the buffer has room for five more pics. It's only a problem when it gets to 0 and stays there.
As to the other error, I'm afraid I can't help you there.
Jul 10, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon N60 35mm SLR Camera Logo
295 people viewed this question
Top Nikon Photography Experts
Ric Donato
Richard C Cohen
Richard C Cohen
JOHN TOPLISS
Are you a Nikon Photography Expert? Answer questions, earn points and help others
