If I refuse to update Itunes, it won't let me sync my Iphone nor my Ipod. So, i updated Itunes thinking I'd just give up the DVD/CD. Before my warranty was up, Toshiba walked me thru reinstalling the drivers for my DVD player. I don't want to do that everytime I update Itunes. Apple has no solution nor Toshiba.
Any ideas?
Solution 1
Check with your manufacturer to see if there are updated software drivers for your optical drive. For more information about updating the firmware of your CD or DVD drive,
Solution 2
Launch Windows Explorer.
Navigate to C:\Windows\system32\drivers\.
Check to see if either of the following 2 files are present. These files from a third-party software vendor are not supported by Windows Vista and can cause driver conflicts with optical drives:
afs.sys
afs2k.sys
If either of the files in Step 3 are present, move them out of the system32 folder. You should keep these files stored somewhere on your hard drive, as some of your older peripherals may require them. If you find that they are required in the future to use a device, you may move them back into the system32 folder temporarily.
Reboot Windows Vista.
Solution 3
Quit iTunes.
Manually remove the GEAR driver software using the steps found here.
Remove any stand alone GEAR software installers from the Programs and Features control panel, if present.
Install the updated GEAR driver.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
Connect your iPod, iPhone, or iPad to your computer.
In iTunes, select your device (below Devices).
Click Summary, and then deselect "Open iTunes when this Device is connected."
In iTunes, choose Edit > Preferences.
Click Devices.
Select "Prevent iPods, iPhones, and iPads from syncing automatically."
If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
