Question about Toshiba Equium 100 PC Desktop
Desktop portrait or landscape as needed.
How do I turn desktop (Vista) to landscape so I can work lying on my side?
  • Anonymous Mar 11, 2010
    Nope. But thanks. I get "personalize" rather than "properties." My son has Vista Home and can do more with his desktop GUI stuff. I have the Premium version and got stuck. But since I see I can't minimize and see all words (no wrap of text) in I.E. 8, I'll just figure something else out. It's hard to work anywhere but at my desk anyway. Thanks!!!
  • joecoolvette
    joecoolvette May 11, 2010
    You may have 'Hot Keys' that have been set to do this. Press, and hold down on the CTRL key, and ALT key, then tap the Up arrow key. No? Then Right-click on an empty area of your desktop screen. On the bottom of the drop down menu that comes up, left-click on Properties. Left-click on the Settings tab. (You are in the Display Properties window. There are tabs across the top. Themes, Desktop, Screen Saver, Appearance, and Settings) Left-click on the Advanced button. (Middle right) Look for the tab - Rotation. Left-click on it. Now rotate your screen.
Ferdinand Ecuacion
    Guru:
  • 440 Answers
Using your keyboard press CTRL+ALT+ Right Key
Posted on Mar 06, 2010
electronic & computer repair& servicre
  • Toshiba Master
  • 12,061 Answers
Depending on the Video card, you can usually select "Rotate" from the icon in the left hand toolbar at bottom left, usually an ATI, Or NVIDIA card, click on the icon, and get into the menu,you should find it there. As I say it is card Dependant Or click Properties on the Video card and select it from there..
Posted on Mar 05, 2010
How to rotate the screen on a gateway touch screen desktop
Hi. I am fairly certain you would need to go into the Windows Control Panel. Go to "Display, then "Adjust Screen Resolution." Where it says "Orientation," change "Portrait" to "Landscape." This is generally how you change the screen orientation in Windows for most PC's. I hope this has helped you. Thanks!
Oct 18, 2014 | Gateway Computers & Internet
Display is landscape not portrait
Step 1:
If u are using windows vista, windows 7 or windows 8, then here is your solution.
Step 2:
go to desktop, and right click.
Step 3:
u will find screen resolution option. click on it.
Step 4:
now click on orientation box, and change it to portrait from landscape, as you said. i hope it will fix your problem.
Apr 10, 2013 | Samsung NC10 Netbook
At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
You can usually find it in the FILE menus
Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
I cannot change my main display on my toshiba equium from portrait to landscape please help me everything is working backwards!
in the right hand of ur desktop screen, u find graphic option.
U jst adjust 4m here, to display portrail to landscape.
Nov 14, 2009 | Toshiba Equium 100 PC Desktop
My daughter has managed to change my display from landscape to portrait how do i get it back to landscape?
Look where the system tray would be on the lower right side of the monitor and look for a display adapter icon. Rich click on it and look for the Hot-Key option. That should tell you what hot-key to revert your screen back.
I’m happy to assist further over the phone at https://www.6ya.com/expert/marnin_498840f315fe3361
Nov 07, 2009 | Computers & Internet
Change Landscape to Potrait veiw
Hello, You need an application called HP MyDisplay, you can download this at the link below, this app will register in which way the monitor is (landscape or Portrait) and when you pivot (rotate) the screen it will rotate the screen as well.
Download: http://www.portrait.com/dtune/hpw/enu/upgrade_instructions.html kr Gijs
Sep 10, 2009 | HP Pavillion s7420n PC Desktop
My suddenly prints every other page in landscape. What is the problem? Tom
It prints in portrait then landscape, portrait then landscape and so on. I use a laptop and desktop with this printer and both are doing it. 2 sided print has not been selected.
Aug 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
Display orientation issue
Right click the mouse on an open area of the desktop, In XP select properties; Vista it's personalize. Go to the display settings and make sure it is set to portrait. Hope this helps.
Jul 02, 2009 | Sony SDM-HS73P 17" LCD Monitor
Change display from portrait to landscape
see on icon tray there will be an icon for you monitor.
Right click on it, it will pop-up a menu, Navigate 'Rotatio' and select 0 degree. Then it will be back as usual.
Thanks
iqbal
Mar 05, 2008 | Toshiba Equium 100 PC Desktop
Toshiba Equium 100 PC Desktop Logo
219 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
