Question about Sampo Televison & Video
I HAVE A YELLOW POWER LIGHT WITH NO STARTUP WHEN POWER BUTTON IS PRESSED
Posted by john1612 on
Melvin Ramos
    President:
  • 2,923 Answers
You are saying that the TV has no display and no sound, right?
Is there any blinking red or green light?
Thank you!
Posted on Mar 05, 2010
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Acer Travelmate 6592G Wont Startup
do the HARD reset. Disconnect the power adapter +battery. Hold the power button by 30 seconds. And then reinstall the power adapter and battery again and test again. this will solve the problem God bless you
Apr 04, 2013 | Acer TravelMate 6592G-602G25Mn Notebook
Toshiba Satellite L450 black screen on startup no fune sound
OK, you get the yellow light which I assume happens when you plug in the power cord even though you have not pressed the Power Button. So, when you pressed the Power Button, did you see any other lights flashing such as the disk drive light? Did you hear the Fan running and the Disk Drive running? Did you hear the DvD/CD drive click once or the light on the DvD/CD drive door flash? If you did see the aforementioned that means your system is trying to boot and might in fact completed the boot process but the Video is not displaying. If it seems like the computer is running by no video is displaying try shinning a flashlight on the screen to see if you can faintly see the icons or something on the screen. If so that means your LCD Inverter is probably bad and needs to be replaced. You could attach an external monitor to the laptop then press and hold the FN (Function Key) + the (F1 thru F12) key that corresponds to displaying on an external monitor. If the video shows on the external monitor then surely you have an issue with the Laptop's screen. If the laptop is not running and you hear no fans, no disk drive running and saw no lights then you probably have a motherboard issue. Get a quote from your local repair shops, then try the guys at: http://www.generalsystemsconsulting.com. They will repair it and ship it back by Fedex or UPS and most times their prices will beat any quote you find including shipping.
Mar 14, 2012 | Computers & Internet
HiI have a dell desktop and won't start. for a second the fan spin than the power button turn yellow. help
hi,
Does your desktop is making any beap sounds? Are you able to see the dell logo on the startup on the screen? Please do let me know these things.
Mar 08, 2012 | Dell OptiPlex GX280 PC Desktop
PC won't start and has yellow power button
sounds like power supply may have died try another if you have know how swap them
Nov 15, 2011 | Gateway 500 X PC Desktop
My Dell Dimension desktop 9150 was running very slow so I shut down the computer. When I pressed the power on button I notice that it was flashing. I pressed the button even holding the power button in...
the constant Green, states that the motherboard is getting Power.
The red/yellow would possibly suggest, that the ethernet port has a fault or possible corruption.
Solution:- remove the Power Lead from the Computer Case.
Remove side panel. take out any ethernet-Cable from the rear.
Locate the CMOS battery, round silver Battery on The motherboard.
For 10 seconds, this should reset The bios, to it,s original Default Settings. Replace Battery, side Panel. And power Lead.
You could also try This. Boot with Hard-drive power Cable Disconnected ( this will Eliminate HD Fault ) same for CD/DVD drive et,c.
Mike @ Compurepair.
Oct 22, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I was watching a Blu-Ray movie this morning and my PS3 just shut off and proceeded to have a red blinking light. I pressed the power button and a solid red light appeared. I pressed the power button...
You have major problems I'm afraid. You need to contact Sony about fixing it/replacing it. Just pray it's under warranty. You could equate this problem with the 360's Red Ring of Death.
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
Reset tv timer pt-61lcx65 after lamp installation
MAKE SURE LAMP DOOR IS COMPLETELY CLOSED,THATS WHY POWER LIGHT FLASHES YELLOW
Jan 10, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Sampo Televison & Video Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
