Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Logo
Posted on Mar 05, 2010
I have a trane furnace that is between 10-20 years old (trane xl-80). there seems to be a white-rodgers control panel inside. the problem is that the blower/fan doesn't always stop once the heating/burner stops and so the furnace continues to blow cold air.
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Mar 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
4328
Points
21
Dodgy relay possibly
I have an Amana Air Command 80 SV Natural Gas fired Furnace that is roughly 19 years old.
it should be above the burner on the outside of the heat exchanger square is shape
We installed White Rodgers 1F81-261 thermostat and Bryant Plus 80T furnace about 2 yrs ago. They worked fine, until now. We tried to set the thermostat to 70F when the room is ~66F. The thermostat...
Does the display seem a little dim? If so replace the batteries. Anything else may be a furnace issue not the thermostat. Look at the furnace and see if you can view any error codes on the circuit board
I have power but no flashing light
Don't think you should have a flashing light...
1helpful
I have a Trane gas furnace with White Rodgers 50A50-474 board is flashing a 2 flash code which is a system lockout-no flame/Check line polarity message. The furnace blower contines to run, but the gas...
Sounds like your ignitor is bad, not lighting the gas. If this happens 3x, then controler goes into lockout and induced draft motor continues to run to extract the gas fumes as a safety.
Either replace the HSI (Hot Surface Ignitor) or sand down the end of the electronic spark ignitor and it's ground rod (they work like an exposed spark plug) to remove the carbon buildup on it so it can spark again. All with the power off, of course!
If you need more help, please ask, I'm glad to help! 25 year HVAC service Tech- residential & commercial systems.
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
I have a trane furnace with a white rodger panel board kind of thing inside. my problem is that about once or twice a day the blower doesn't shut off once the heat stops so the blower just continues to...
When it does it again, look at the control board for a flashing light. If there is one, it will indicate an error code. On the wiring diagram there should be a diagnostic chart that will help pinpoint where the error is occurring. Usually it is a dirty air filter that causes an overheat code. Check it out!
1helpful
Trane gas furnace with White Rodgers 50A50-474 board is flashing a 2 flash code which is a system lockout. The furnace blower contines to run, but the heat stops. I can reset the furnace and the system...
If this is a direct vent unit, check the PVC air intake at the furnace for debris. There is a screen at the furnace connection and as cold air enters into the burner chamber it frosts up on it. If there is any blockage, it restricts the air inlet. If the furnace ignites, it melts the frost and works fine. It happens mostly at night. Let me know if you find this. Thanks.
1helpful
Thermostat wiring
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Thermostat wire color codes explained.
Please note. Not all installers use the proper color codes when they install or replace equipment. It may be necessary go go to the furnace or outdoor unit to verify what wires are for what purpose. Also be sure there are no splices in the wire that could change the wire colors between components.
  • R (red) or Rh (Red heat) 24 volts from equipment.
  • Rc (Red cooling) 24 volts from transformer in cooling equipment.
Note: If only furnace has a transformer and cooling equipment does not jumper Rc and Rh.
  • W (White) sends 24 volts to furnace control to start the heating cycle.
  • W2 (no standardized wire color, usually whatever wire color is available) controls second stage heat.
Note: W2 is most often used for heat pumps to control what is called emegency heat or Auxillary heat, and most often will use the white wire.
  • Y (yellow) often (blue) is used, controls cooling unit (outdoor condensing unit) also is used for heat pump heat.
  • Y2 (no standardized wire color, usually whatever wire color is available) controls second stage cooling.
  • G (Green) controls the fan "on" operation of the furnace/air handler. Also often is used to start the blower for many electric furnaces.
  • C (common) most often brown but can also be black or other color available to installer.
  • O (orange) Energizes heat pump reversing valve for cooling (Trane and most other brands).
  • B (Blue) Energizes heat pump reversing valve for heating (Rheem, Ruud and Weatherking).
1helpful
Thermostat wiring
99.99% of the modern residential units use only one transformer to power the 24 volts for both the furnace and the a/c unit. It will be located in the furnace. The outdoor unit will not have its own transformer unless its reeallllly old. Place a small jumper wire between w1 & w2 terminals on the thermostat. (The lux brand is not the professionals choice) (if you have problems replace with a honeywell or white rodgers brand).
Good luck.....
Top Omega Tools & Hardware - Others Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Larry Ng
Larry Ng
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
