Question about NorStar M7310 Corded Phone
Lines ring to intercom
Trying to call out on a Norstar M7310 phone but after pressing any of the line buttons, the call rings the intercom at a nearby phone set.
Posted by shamfeldt on
george peters
    President:
  • NorStar Master
  • 860 Answers
It sounds like although they're labeled as line buttons actually they're programmed as station buttons.
If you press feature *0 and one of the buttons it will tell you what the button is programmed as.
Also did you try pressing the intercom button then dialing 9? that might be the way the set was programmed.
Posted on Mar 05, 2010
How can I program an all call button on the NorStar Meridian M7310 Phone to intercom everyone in the office simultaneously?
I guess you want a page key programmed on your set. press feature *3, press a memory key, press feature 610. This key pages all sets when pressed.
Dec 07, 2016 | NorStar Meridian M7310 Phone
I added new line at Norhern Telecom Meridian System but line is not shown on my M7310. How to add line on phone
First press feature *0 then the intercom button this will tell you the extension number. write this down.
Press feature **266344
then 266344
should now say terminals and sets on the phone.
press 1st lit arrow on the left side of phone
enter extension number or press find and enter extension number.
press the top arrow on left side of phone until you see line assignment
press list
when you get to the new line press change until the line says appear only(no ring) or appear and ring(rings on the phone)
press rls when done
Jan 11, 2011 | NorStar M7310 Corded Phone
Our office has a combination of Norstar M7310 and Norstar M7208 phones. One of our M7310 phones died today and I wanted to trade it out with a M7310 that was in my office. I followed how to turn off the...
Dial "F * 0" (Feature, star, zero), which is Button Inquiry, and press an intercom button to see the extension number of the telephone. If Set Relocation is set to "Yes", then the extension number & mailbox will follow the phone when it is moved. Move only two phones at a time, and wait until they completely "boot-up" before moving additional phones.
Hope this helps.
Aug 04, 2010 | NorStar M7208 Corded Phone
Hi there ... We have 4 lines in the office but on one of our M2000 series Meridian phones only the first 2 line buttons receive a dial tone ... How do add lines 3 and 4 to the next 2 buttons?
Programming is done on M7310, M7324 and T7316 sets.
To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program the new lines on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the next key (bottom right arrow) till it says 003:unaaign.
press the chng key till the screen says appear&ring
Press the next key(bottom right arrow)
The display should say line 004: unassign
press the chng key til the screen says appear&ring
press the Rls key when finished
Jul 03, 2010 | NorStar Meridian M7310 Phone
Ringing multiple intercom numbers at once
That was a good solution to the problem. way to go.
Feb 10, 2010 | NorStar M7310 Phone
M7310 phone line ringing does not appear on receptionist phone
Feature **266344
Password 266344
Terminal & Sets
Press Show (Top Right Button)
It will Ask Extension Number
Change to Appearance & Ring
Sep 29, 2009 | NorStar M7310 Corded Phone
Incoming calls ring on intercom rather than appropriate line.
Somehow you might have taken the lines off the extension. I would double check that under line appearance, that extension is set to "appear and ring" for each line.
Dec 08, 2008 | NorStar M7310 Corded Phone
I have a NorStar M7310 phone -I am on a conf call - how do I mute the line where the other parties cant here
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
Dec 04, 2008 | NorStar M7310 Corded Phone
Only First Phone in the system will ring on incoming calls
These manuals are available on the norstar web site.
Jul 08, 2008 | NorStar M7310 Corded Phone
Telephone ringing problem
Okay first you'll need to know the 2 digit "Set" number for your Phone.
Press "Featire" *0 then Intercom to get the 2 digit number.
Okay Now we need to configure:
Press "Feature" **CONFIG or **266344
Press: Next until "Sets" appears "press Show" Top Right Button
Enter 2 digit "Set Number"
Press Next Until You Get Ringing Lines
Hit the "Change" Button to Turn the Line to "Yes" to ring
Do this for each Line you have that you want to ring.
Done, Please Rlease.
May 27, 2008 | NorStar M7310 Corded Phone
NorStar M7310 Corded Phone Logo
166 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
