Home Logo
Posted on Mar 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an old AquaWhirl tub that was out of commission for several months because of a breaker problem. I replaced the breaker but when I turn on tub I get 5 seconds of normal whirl followed by a big burst followed by 5 seconds of normal... Is there air in the lines or some other issue since it sat dormant for so long?
Anonymous
Level 2:
  • Expert 332 Answers
  • Posted on Mar 05, 2010
Anonymous
Expert
Level 2:
Answers
332
Questions
0
Helped
140912
Points
780
Due to your tub setting for a long period of time, you have a simple air lock in the jet hoses.
Find the pump - locate the jet farthest from the pump and using a funnel slowly pour water in that jet until water starts coming out of the other jets.
Turn you tub on it should work fine. If this does not solve your problem you may have to loosen the top hose at the pump and allow the air to escape while being replaced by the water you are pouring in
3answers
Hot tub will not turn on trips offbefore I can unlock it New filters and water tubh one month old
You need to write a better explanation. If the circuit trips as soon as you turn on the pump then there is a short circuit. Either the pump motor or the wiring. Unlock what?
Jul 12, 2019 • Pool & Spa
Jacuzzi j325 my tub is about 7 years old, I noticed the tub had no power so I checked the breaker in circuit panel and it was tripped, I reset the breaker and by the time I get back to the tub it trips...
There are several things that can cause this problem. The first is you just have a bad breaker, next is your heater unit is bad, lastly the pump motor could be bad. There is also the possibility that the motherboard is bad again.
The hot tub reads - - - and has power but nothing is working.
this problem is over a month old so i am not sure if you still need the help.Start by turning off the breaker. Unplug everything from the hot tub i.e. pump, heater, air blower, light - anything connected to the spa control box.
Now turn on the breaker.
Check the voltage coming out of the transformer in the spa control box. You may have a bad transformer or a bad circuit board. If you have power coming out of the transformer going into the circuit board, do the following:
If it doesn't blow the breaker then systematically do the same process but plug in one item at a time starting with the pump first until you find the problem.
Rod
US Parts Center
My hydropool spa is tripping the circuit breaker. I moved my hottub off the deck onto a concrete pad next to the deck last summer. No problems, then over the first winter I went out one day and the...
it sounds to me like your hot tub has bugs take the control panel apart and clean the bugs out of it. if you have ants in the area they will get into the controls and cause it to trip out. i had similar problem with apump until i found the ants
I have a 15 year old Hydropool Gold Series hot tub that I bought used a month ago. We got it all hooked up and working great but was told the timer never worked so it ran 24/7. Yesterday my husband turned...
If you can find the points on the timer try sanding them down. If they were burnt and stuck the spa would have run continuous. When you pulled the timer you may have broken them free but a burn would have kept them from making contact. I hope this helps, if not you might try reversing the leads coming into the timer or wherever you unhooked it to take it out. good luck.
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
2helpful
2answers
Is this crib on the recall
Yes it is under the recall.
The death of two more infants trapped in Simplicity bassinets prompted the Consumer Product Safety Commission to re-announce its August 2008 recall of the child beds on Thursday.
The recall was first announced last year after the death of two other children. A total of four deaths have been reported to the commission involving Simplicity bassinets.
The recall includes more than 900,000 bassinets sold as far back as 2001 and as recently as last year.
The hazard in the Simplicity 3-in-1 and 4-in-1 convertible bassinets stems from metal bars spaced farther apart than federal standards allow, the commission said.
If Velcro-attached fabric that covers metal bars on the bassinet is attached improperly, a pocket can be created where children can become trapped, the commission said.
Children also can become stuck between the bassinet's metal bars without the fabric attached, the agency said.
In the latest two incidents, a 6-month-old girl in Fort Worth died in January after she was trapped between two exposed bars on the bassinet.
In September 2008, a 2-month-old girl in Demorest, Ga., suffocated when she was caught in a pocket of fabric, which was not properly secured to the bassinet.
The commission also received two other reports involving 10-week-old and 3-month-old infants whose heads became trapped between the bassinet's lower bar and mattress. The infants were freed and uninjured, the commission said.
The recalled bassinets were manufactured before May 18, 2008, and include some sold under the Graco brand and others with Winnie the Pooh characters printed on the bed's fabric.
Simplicity is owned by children's furniture manufacturer SFCA Inc. of Reading, Pa.
The model numbers for recalled Simplicity bassinets are: 3000, 3010, 3011, 3012, 3013, 3014, 3015, 3016, 3017, 3020, 3025, 3026, 3027, 3030, 3040, 3045, 3046, 3047, 3050, 3060, 3070, 3111, 3112, 343-8363, 343-8399, 5730, 5750, 8383, 9250 and TD250, the commission said.
Model numbers on the recalled Graco-branded bassinets include: 3000CL, 3010HAV, 3011WHE, 3011WHK, 3014NGS, 3016LAU, 3017NCB, 3025C, 3030SAR, 3050SAR, 3111DPC, 3111ZOL, 3112DOH, 3122TGT, 5730FKB, 5750SAR, 8393, Graco said in its own recall statement.
Owners of the recalled bassinets can return the beds to the stores where they bought them, the safety commission said. Sources: http://www.latimes.com/business/la-fi-crib-recall21-2009aug21,0,4022989.story
2helpful
3answers
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
