The Minolta X-series (X-300/370, X-570, X-700) were known for this
issue. Two capacitors under the top and bottom covers go bad over time.
They prevent the shutter from releasing, so you cannot wind to re-****
the shutter. If you're handy at these things, you can buy the caps,
remove the covers, solder in the new caps, and be fine. This issue is
well known and you can find instructions on the web. Or you can send it
in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at
$58 incl return postage. Look him up on the web.
changing the batteries have no effect on film transport, just a coincidence. take the bottom cover off and check the white plastic gear on the film take up side of the camera. if it is broken your X700 may not be repairable as no new parts are available.
push the re-wind button in and try to charge the shutter again. remove film first. if it still just goes part way then a gear is stripped. try to find a camera repair shop that may have good used parts available.
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Are the batteries good ,is the battery cap and contacts clean? Can you fire the shutter? Move select off auto and try to release the shutter. If the shutter fired off auto and will not fire on auto with good batteries. Either the shutter or flex circuit must be replaced. There are no new parts avail. for the X700.
One other item for the X700. check to see if the shutter fully traveled on the last shot.
Is the re-wind button stuck in? If so it can be released by moving the take-up sprocket manually. If that did not work there is a broken take up gear. This was a common problem with the X700, a white plastic gear was used at the bottom of the take up spool mechanism that just was not strong enough especially when trying to get just one more shot from the roll of film. No new parts are available.
