Failed pick up fax in memory
SOURCE: THE FAX MACHINE CAN RECEIVE THE FAX IN THE MEMORY BUT FAIL TO PICK UP
My office fax machine can receive the fax in the memory, but it does not print it.
SOURCE: incoming fax
IT SEEMS YR MACHINES TONER /DRUM IS EMPTY OR PAPER S ARE EMPTY OR THE MACHINE IS NOT SENSING THEM . PLEASE REPLENISH TH SAME. IF VERYTHING IS OK,THEN YOU NEED TO CLEAR THE MEMORY OF THE UNIT, WHICH COULD HAVE GONE CORRUPT. USE THE PANASONIC SERVICE CODE: IE: PROGRAMME #9000* AND THEN 550 TO CLEAR THE MEMORY. WILL SOLVE THE PROBLEM HAPPY FAXING OMNIPRESENT
