You might have bad solder connections where the speaker terminals attach to the circuit board inside the case. Mounting screws inside holding circuit boards in place may also have become loose. Often there are ground connections that depend on these screws being tight.
You may also want to check your speaker wires. The wire may be making a poor connection at the terminal. Try cutting a couple of inches off the end, stripping the wire and reconnecting.
Hope this helps. Thanks for using Fixya!
