It sounds like your Kenwood A58 amplifier may be having a technical issue that could be caused by several factors, including an internal component failure, a wiring problem, or a software issue. Here are a few suggestions to help resolve the issue:
Check the wiring: Make sure that all the wiring and connections to the amplifier are secure and properly connected.
Power reset: Disconnect the power to the amplifier, wait a few minutes, and then reconnect it to see if the issue is resolved.
Update software: If your amplifier has firmware or software updates available, it may be worth updating to see if the issue is resolved.
Contact the manufacturer: If the above steps do not resolve the issue, it may be best to contact Kenwood's technical support for further assistance.
It's important to handle the amplifier carefully to avoid causing further damage or issues. If you are not familiar with the internal workings of an amplifier, it may be best to seek help from a professional for a repair.
1. System restart/looping issues - In addition to steps discussed earlier, we can resolve the issue by deleting the hpfax.ini, and the hpfax_print.gpd from C:\WINDOWS\System32\spool\drivers\W32X86\3\Old\1, restart the PC, and attempt an install. If the issue is not resolved we would need log files for this issue.
2. PS C4700 – Freezing on HP Logo while wireless is enabled Issue. The default wireless setting would be Security type – WPA2 Personal & WPA Algorithms – AES Change it to Security type – WPA Personal & WPA Algorithms – TPIK. Let me know if this helps resolve the issue.
We will discuss these issues on our weekly call on Wednesday. Please share your findings.
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer 2. Check if there any Documents stuck in Queue 3. Check if all the software/Drivers are correctly Installed 4. Check if the HP Printer icon is the default icon to print 5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click here to download the Utility and save on Desktop location Run the HPPDU file and follow the instruction on screen to fix.
This is very useful tool for your future assistance too. This will resolve your issue.
1. Unplug the power from the laptop and remove the battery then press the power button of the laptop for 15 seconds
2. Put the battery back in, turn on the laptop without plugging the power to the laptop (If this didn't resolve the issue)
3. Remove the battery and press the power button of the laptop for 15 seconds, after that, plug the power cord and turn on the laptop (if this didn't resolve the issue)
4. Remove the power cord and press the power button of the laptop for 15 seconds, disconnect the Hard drive and turn on the laptop (If this didn't resolve the issue) reconnec the hard drive
5. Remove the Optical Drive and turn on the laptop (If this didn't resolve the issue) reconnect the optical drive
6. Remove the memory chip, if you have 2 memory chips installed in the 2 memory slots (remove both of them) now test each one of the memory to each slots turning on the laptop. (If this didn't resolve the issue) Put the memory chip back in
7. Reseat the CPU and try to make sure that it's installed properly. Turn on the laptop and test if it's gonna work (If this didn't resolve the issue)
8. Reseat the power cords coming from the power supply of the laptop and test the laptop. (If this didn't resolve the issue)
9. Disconnect everything and just leave the CPU installed and turn on the laptop.
10. If all else fails, there's a big possibility that the problem may be with the power supply or the motherboard of the laptop.
(Note: you may try to clean your computer if there is a large amount of dust. You may try to remove the CMOS battery)
I appreciate you work to resolve the issue on your own. I am providing you a weblink to resolve the faxing issue. This web page will help you in graphical way to resolve the issue else you could chat with HP online technician free of cost.
Have resolved issue of Sync Failure on my SGH-F480T by simply killing
off all calendar entries and contacts in the phone and resyncing with
outlook. ONLY resynced the next 3 months worth of appointments and all
OK now :-) NO THANKS TO SAMSUNG WHO SUGGESTED A FIRMWARE UPGRADE WOULD
BE REQUIRED TO RESOLVE THIS ISSUE :-(
