Question about Microsoft LifeCam VX-3000 Web Camera
The picture quality is very poor. Picture is fuzzy.
The picture quality is very poor. Picture is very fuzzy. I have tried to make adjustment, but to no avail. Any suggestions?
Posted by dlsmith237 on
Isabel Coburn
    Sergeant:
  • 212 Answers
Did you turn the ring on the camera itself? The camera does not automaticaly adjusts itself. You must turn the lens to focus manualy.
If nothing works and you just bought this camera, call microsoft and they will help you more.
Posted on Mar 05, 2010
Poor picture
its a mainboard issue .It can be fixed easily by replacing the mainboard or the hard way by fixing the excact one (the second option requires advanced electronics and expertise
Jun 18, 2014 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Amp transmitting fuzzy picture
It could be dirty contacts, corroded connectors inside, or dirty from atmospheric pollution or even dust.
Other degradation may result from a solder joint developing corrosion now, or a diode getting leaky.
It is repairable, but it is a time investment.
Mar 23, 2012 | Channel Plus DA-8200HHR Amplifier
Poor picture and colour quality on hd through hd box red is pink fuzzy hd picture
You need to check the resolution of your TV thru your input setting, try to check which will give better picture quality between 1080 or 720 settings. Also secure that your input setting as either HDMI 1 or 2 or 3, you can use the original remote and change setting by pressing input in cycle.
Jul 08, 2011 | Televison & Video
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
Poor picture quality, the picture is blurred and
You have problem with convergence. Have you tried adjusting in the users menu. This is a common problem in this type of TV, usually two convergence amp need to be replaced and sometimes sets of resistors are also to be changed.
Mar 02, 2010 | Sony KP-43T70 43" Rear Projection...
Why is my webcam picture on my pc fuzzy
i hate to be blunt but the reason that the picture is fuzzy is because if the type of cam. its about a $20 cam logitech. if you really want quality picture you will have to pay more for your cam. i have a logitech also and it really has crappy pictures. i bought a more exspensive one and
the pictures are very clear. sorry to say but its the cam its self. even if you adjust it in settings the picture really will never be clear.
Nov 13, 2009 | Logitech Webcam
Poor picture
adjust the antenna! or the cable connection could just be loose or dirty!
Jun 18, 2009 | Televison & Video
Blurry picture
Try adjusting the focus ring around the lens. Poor quality try adjusting room lighting or you may need to upgrade to a better webcam.
Jun 09, 2009 | Logitech 961462-0403 Webcam
Poor pictre quality
This set has 3 CRT's (picture tubes)
Remove the back bottom cover
Clean the CRT's with windex and a soft cloth.
(Find the Screen/Focus block)----Remove front grill cover and panel which covers the Screen/focus block.
Cover 2 crt's and adjust the focus control for remaining crt---(using the convergence pattern in the menu for the set)
adjust for the best focus.
cover that crt and move on to the next crt using the same procedure.
After setting the focus on all 3 tube's you will have the best focus possible for this set. If picture is still bad, you have bad crt's and the set is junk.
Cost to replace the CRT's is enormous!
Craig
May 08, 2009 | Televison & Video
Logitech Quickcam Chat
Hi Thomas,
Have you tried adjusting your resolution? To maximize the quality of video/picture that your webcam can capture, Turn the resolution into 1.3megapixel. Adjusting the resolution is by clicking the arrow above the Video Option.
Oct 25, 2008 | Logitech Quickcam Chat Webcam
Microsoft LifeCam VX-3000 Web Camera Logo
165 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
