Mitsubishi VS-50111 50" Rear Projection Television Logo
Bryan W Posted on Mar 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Colors out of alignment
See the following images for the issue with my TV, which occurred suddenly this morning, and seems to have gotten worse later in the day, despite not being used. From what I have gathered, it seems to be something with either a tube or a convergence circuit. How easy is this to repair?
http://tinypic.com/r/a2gqdz/6
http://tinypic.com/r/2zznss0/6
Anonymous
Level 2:
New Friend:
  • Expert 157 Answers
  • Posted on Mar 05, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
157
Questions
Helped
48689
Points
265
If you have background in electronics, you can do it. The difficult part here is on how to access those convergence amp(convergence circuit output IC). By replacing those 2 IC and some resistors sometimes, adjust the convergence and your done. Good Luck
Televisions colors are not aligned
Convergence issue and a magnet will only make matters worse.
Google the model number with "problems"
2helpful
2answers
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
2helpful
The screen seems to have two of the same image, green and red.
Yes.
The fix is to replace the two Convergence IC's( STK392-110's) with STK392-150's. They are located to the right side of the chassis and mounted to large heat sinks. Be also on the look out for some burnt resisters and or discolored resistors that failed becuase of the IC's failing. These would be located just to the left of the heat sinks. If they are burnt or severly discolored, you will need to replace them with the exact valued resistors. In this high current circuit it is a must.
I hope this helps,
Skyassoc
Turned on TV this morning and the colors were out of alignment. TV works just looks funny. Tried the magic focus and got most of the screen lined up....except the upper left hand corner where the colors...
There is a convergence output kit for this set. There are probably resistors in the convergence circuit that are starting to loose there values. If you are going to have the set worked on have them install the whole kit which includes the convergence outputs and resistors. Thanks
3helpful
Our panasonic HDTV-model #PT47WX42F all of a sudden has 3D images- I've tried to correct with the convergence buttons but can't get the colors aligned--can you suggest something to try or is it...
You can repair that issue by installing a convergence repair kit. You can get the repair kit for your model which has the parts and detailed instructions at the following link listed under the Panasonoc repair kits. www.tvrepairworld.com
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
