You may have simply tripped a breaker, but if not it may be this.
This may be a faulty door switch. If you look into the door locking mechanism carefully, you can see a small plastic bulb located either to the right or left of the locking Jaw. Sometimes this switch arcs out if it is opened under load. Sometimes it just wears out or bends back if the latch is pulled too hard. Disconnect the power, unscrew the front panel of the Dishwasher, avoiding the fiberglass padding. Look near the locking jaw for 2 wires going to a switch.
Use your own judgment here now.
If you are comfortable with electricity and experienced enough, use a low amperage automotive fuse (the plastic type) 5 amps should be enough.
Slide the clips onto the fuse, then tape the exposed parts with electrical tape, and try latching the door.
If you can choose a cycle and the lights come on, you have found your problem. If not, you will likely need a technician to diagnose for you since this sounds like an electronically controlled model.
