Question about Bernina Activa 130
Old style 830... having trouble doing automatic stitches
I received this machine as a gift from a friend. Have been using it in straight stitching, zig zag, and it does fine. Tried to do the blind stitch tonight. It just stitches a straight seam to the right of the center line. Have 1-20 selected, stitch width at 3, special foot attached, stitch length at about 2 1/2.
And the stitch selector on number 1 for blind stitch.
Any input??
Posted by stermolle455 on
R.A. Ellis
  • Bernina Master
  • 12,731 Answers
If your machine has not been professional serviced recently or you have not cleaned and oiled it lately, then you might refer to your owner's manual instructions for oiling. I would suspect that perhaps the oil has hardened and is preventing the machine from operating properly--perhaps some of the selector lever/dial mechanics are not moving internally. Use liquid Tri-Flow Synthetic Oil (usually available at the hardware store) and put a drop or two every place that the manual recommends. Direct a hot hair-dryer into the internal works of the machine. (I usually let it get pretty warm to the touch - but make sure to stop periodically because your hair dryer may overheat.) Test your machine. If you can determine that the selector lever/dial mechanics are not moving, you can try putting a drop or two of oil in its metal joints and working it gently back and forth to loosen. Depending on how hardened the oil has become, you may have to repeat oil/hair-dryer process several times before things loosen up. Once it is working again, be sure to clean and oil regularly. (I recommend a good quality oil, ie Bernina oil for mechanical machines. It may seem expensive but it lasts a long time if you use only one or two drops each spot and, IMHO, is worth it in the long run. I do NOT recommend 3-in-1, WD-40, cooking oil, or the cheap sewing machine oil from fabric departments.) You have a wonderful machine and it will continue to serve you well if you treat it well. Suggest cleaning/oiling every time you change a bobbin, every 8 hours of continuous use, or every six months if it is not in regular use.
Posted on Mar 25, 2015
paj42
    Genius:
  • 1,116 Answers
Take the machine to an authorized Bernina dealer for service - make sure to fill out the service slip with any problems you are having.
Posted on Mar 05, 2010
How to remove the top cover of Bernina 830. My machine keeps telling me to rethread. It stitches about 10 stitches then stops
Which Bernina 830 are you referring to? (Yeah, it was crazy of Bernina to use the same numbers to identify different models...). There is the old Bernina 830 Record and the new computerized Bernina 830.
Have you tried rethreading the machine? If so, be sure to ALWAYS RAISE the presser foot. Verify the thread path is correct.
Apr 10, 2018 | Bernina Sewing Machines
Setting stitch length on a old wizard sewing machine
This may be helpful:
Wizard brand sewing machine Custom Style
Otherwise, search for:
Make Model sewing machine
Oct 12, 2017 | Sewing Machines
My old 830 will not do zigzag stitch are any other fancy stitch. Will only straight stich
Most likely, it has seized due to old oil that has dried. These old machines do love regular oiling and cleaning. Usually the first to be affected are the stitch selectors, feed dog drop, needlebar or handwheel.
Wheel on right side that controls the needle up and down is very tight...
Aug 30, 2017 | Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
Supply of new stitch cog for Bernina 830 Record
I don't know what a stitch cog is by your definition but I suspect that you may be referring to the cam stack worm gear, part # 310 007 03. These gears are available, however those produced and sold as after market parts online have ranged from bad to very bad. I would suggest that you find an OEM part (not a reproduction) that are still available from time to time on EBAY etc.
Changing the gear is not as straight forward as it may look. The proper replacement requires: 1. removal of the cam stack without damaging the machine parts, 2. removal and installation of the new gear with the correct alignment of the individual cams, 3. installation of the cam stack and pattern indicator without axial play, 4. correct parabola timing of the main-shaft worm wheel and cam stack gear, 5. synchronization of the zigzag and automatic cam parabolas, 6. pattern indicator timing, 7. checking and adjusting the automatic needle position. SewTechnical Home
Jun 14, 2014 | Bernina Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
Do not know how to set the machine for simple straight stitch.
I don't know your model but most machines have 2 common setting devices, namely a stitch width dial (how wide the needle swings) and a stitch length dial, how far apart the stitches are. So a normal straight stitch is "width" set to zero and "length" set to 2.5. If the machine has several different stitches then there may be a "stitch selector" too where you can choose the stitch style, ie zig-zag, 3 step zigzag, blind hem stitch etc.
You could try to locate a manual or threading diagram at various websites or visit sewing.about.com which gives good general information on threading and use.
Mar 01, 2011 | Singer 1725
My Bernina 830 Sewing Machine is not sewing the 1-20 stitches, only straight stitches.
If you are selecting patterns but only getting a straight stitch after making sure you have set the width, there may be a chance that the pattern camstack has split and the selector finger is stuck in the split, more common than people think,
take the top off the machine and check
Oct 23, 2009 | Bernina Sewing Machines
I recently received 2 White sewing machines: a #2380 and a #1780 Quilter's Star. With the #2380, I can't get it to sew a large(long) straight stitch, even though the stitch length is set clear to #4. At...
Re the bobbins it is the depth that sounts and some of the plastic bobbins are the same as the metal ones(I used to sell sewing machines)so as long as they are same depth when put side by side and same circumferance then another type will be fine. Ive only found 2 different depths in the plastic ones so I dont know which you have. Not sure what has happened with your stitch lentgh. Check the stitch selector is properly on a straight stitch and that the other stitches are correct. A s/mach technician may be able to alter it for you but yo can do no more on that.
Sep 07, 2008 | White Sewing Fashionaire Sewing 2380...
Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
May 08, 2008 | Sewing Machines
Sewing Machines Logo
222 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
