Microsoft Office Professional 2007 Full Version for PC Logo
Posted on Mar 05, 2010
I am unable to launch any microsoft office programs. Whenever I double click on any program, it doesn't launch at all. Before, I was able to launch all the MS Office programs. When I right click to go to properties, under the shortcut tab, everything is grayed out. Please assist.
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Mar 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
5346
Points
25
Try to launch your programs directly from the installation directory, by default: C:\Program Files\Microsoft Office
If you are able to launch them, it is only the shortcuts that are somehow modified.
If it's not the case, I recommend you to repair it with the installation disk.
How do i install speech recognition using microsoft word 2007
To install speech recognition by using Add or Remove Programs, follow the given steps:
Click Start, and then click Run.
Type control appwiz.cpl add new hardware in the Open box, and then press ENTER. The Add or Remove Programs window is displayed.
Click Microsoft Office, and then click Change.
Click Add or Remove Features, and then click Next.
Under Features to install, double-click Office Shared Features.
Double-click Alternative User Input, click Speech, click the down arrow, and then click Run from My Computer.
Click Update. Speech recognition is now available in all Office programs and other programs for which it is enabled, such as Internet Explorer.
2answers
Sir my pc ms office excell and word files not opened some errors came
Click on Start button and click on RUN command. If you don't see RUN command then right-click on the start button and select Properties and select Classic Start menu and Apply and Ok. One you see the Run command, type in winword.exe or word.exe and press ok. If this command doesn’t launch your word application then files might have corrupted. Therefore, you need to repair the whole office suite. To do so, type appwiz.cpl in the Run command box. Locate Microsoft Office program and right-click on the program and select Change and then repair. This may take some time and once this is done, restart your computer and your application should be running up smoothly.
Problems accessing microsoft office 2007
If that's the case the VIRUS might still be present in your system or it has corrupter your MICROSOFT Office installation. I suggest you do the following:
1. Buy ANTIVIRUS product - ESET or NORTON
2. Perform deep system Scan
3. Or Your can install Trojan Remover 6 - run a system scan
After installing the products above if the problem still persist:
you need to repair you MSOffice Installation:
1. You need to have the installation CD do the following:
Run the Detect and Repair tool from Add or Remove Programs loadTOCNode(3, 'moreinformation');
  1. Click Start, and then click Control Panel.
  2. If you are running Microsoft Windows Vista or Microsoft Windows 7, do the following:
    1. Click Programs, and then click Uninstall a Program.
    2. Click the name of the Microsoft Office Edition 2007 you want to change, and then click Change.
    3. Click Repair, and then click Continue.
    Note In Classic view on Windows Vista or in Icon View on Windows 7, double-click Programs and Features. Click the name of the Microsoft Office Edition 2007 you want to change, and then click Change. Click Repair, and then click Continue.
    If you are running Microsoft Windows XP, do the following:
    1. Click Add or Remove Programs.
    Note In Classic view, double-click Add or Remove Programs, click the name of the Microsoft Office Edition 2007 you want to change, and then click Change. Click Repair, and then click Continue
Please don't forget to RATE. Thanks. Cheers!
2helpful
2answers
Can't activate microsoft office home & student 2007
Once Microsoft Office 2007 has been installed with no product key, proceed with the following steps:
1. In Windows Explorer, browse to the following folder:
C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en\
2. Right click on Proof.XML file, select “Open With…” in the right click menu.
3. In the “Open With” window, select Notepad to be used to open the XML file. In Vista, if you can’t see the Notepad option, simply double click the “Other Programs” to unhide it.
4. Scroll down to the bottom of the Proof.XML to locate the following lines:
</Feature> <Feature Id=”SetupXmlFiles” Cost=”1248′>
<OptionRef Id=”AlwaysInstalled”/>
</Feature>
5. Change the AlwaysInsalled to neverInstalled so that the line looks like following:
<OptionRef Id=”neverInstalled”/>
6. Save the Proof.xml file. In Windows Vista, you may need to take ownership and grant full access permission to yourself before able to modify the file.
7. You can now launch Microsoft Office 2007 application such as Word, Excel, Powerpoint, Outlook and etc without prompting for activation.
4helpful
Cannot open links in outlook express does not open IE if i click on any links in emails
First go to "programs and features" uninstall Google Chrome.
Go to "Set Default Programs" (Control Panel>Default Programs>Set Default Programs)
Select Internet Explorer and click Set this program as default
Select Microsoft Office Outlook and click Set this program as default
Run Registry Editor (regedit.exe) and browse to location: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Ext and change the value data of all DWORD entries from 1 to 0.
Launch Internet Explorer first; launch your Mail client (hopefully Microsoft Officer Outlook).
Check if all is well and you are now able to open links from within your Mail client.
34helpful
3answers
How to find 8 characters refferal key
  • Click the Windows Start button to open the directory.
  • Click the All Programs button to open the list of programs.
  • Click the Microsoft Office folder to open the list of programs.
  • Click a Microsoft Office program (such as Word or Excel) to launch the Activation Wizard.
  • In the wizard, enter your 25-character activation key. NOTE   If a box appears on this screen to type your 8-character referral key, you may leave the box empty. The referral key is not required to activate.
  • Click the Install Now button.
  • Re-open any Microsoft Office program.
  • Click Internet Activate on the pop-up screen to complete activation.
  • Hope this Helps, Please Rate My Response! Thanks!
    PREM
    13helpful
    3answers
    MS OFFICE 2007 KEYS
    PREM
    Unable to work with Internet Explorer... :-(
    It sounds as though the IE7 application may be corrupted. Try removing IE7.
    To Remove IE7: Go to Start > Control Panel > Add/Remove Programs > Select Internet Explorer 7 > Select Remove. IE is a core component of XP. Hence, your machine will revert to IE6. Reboot pc. If you like IE7, visit Microsoft and download a fresh copy.
    Good luck.
    Unable to run Professor teaches Microsoft Office 2003 on Windows Vista
    click start menu setting control panel. add or remove program. remove that software. then. insert the cd try to install again and. finish the setup process. then click startmenu programs. see thre your program icon wil appear. click on it start using it. if any error comes. send error message. thanks
    Top Microsoft Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
