I have had the Philips HTS3455 for at least 2 maybe 3 years. I have gotten every component to work except the AUX/DI to work. This week I connected my PC to my television (using VGA cables) and attempted to connect the audio out put of the PC to the HTS3455 using the RCA audio in jacks located on the back of the HTS3455 and selecting AUX with the remote control. No audio comes out. If I connect the audio from the PC to the mp3 in put on the front of the HTS3455, proper audio comes out, but there is also an annoying hum distorting the sound. Has anyone else experienced this issue? I'm hoping to get the AUX/DI to work or the mp3 to work without the hum. Any suggestions would be greatly appreciated.
Thanks
Hum first,,, anytime you have 2 devices with sound running to a cable or ant equipted TV you will get a hum as they are grounded off curcuit. HumEliminator (radio shack). You didn't tell us if your PC had been enabled in control panel for either device. I have had no luck using the rear aduio output on any computer. Front headphone jack on PC does not need enabled and will work better for this. Unless you use a USC codet interface which is better yet for CD quality in sound. Also make sure the Aux inout is enabled on TV as well. Direct Input would be the same. Lastly,,you are 100% positive the backside is input and not actually out put or gaming inputs.
