Coolmax HD-211-U2 Silver Slim USB 2.0 2.5 Inch HDD Aluminum External Enclosure (DSCMXHD211U2) Drive Case Logo
Posted on Mar 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Appears as working properly within the device manager. But it does not show up in "My Computer". I have updated the drivers but still nothing.no sign in disc mngmnt either Any advice? Thank you!!
electronic & computer repair& servicre
Level 3:
  • Master 12,061 Answers
  • Posted on Mar 05, 2010
Master
Level 3:
Answers
12061
Questions
0
Helped
4007888
Points
36390
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Video card has a problem because windows cannot load the drivers (code 31)
Error code 31 is an error displayed in the device manager when the drivers are messed up. "This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)." This code will appear when the graphic card drivers are having issues.Protecting Drivers
To protect your computer system and drivers, always create a restore point before downloading or updating any program.
Right click "My Computer" and select "Properties."
Look under the "System Protection" tab in the System Properties popup box.
Click on the "Create" bottom to set a Restore Point when the computer is healthy and running well. Good computer maintenance means setting a point once a month.
Name the point with a phrase that has meaning to you, like "before driver update."
If a corrupt driver sneaks onto your computer, this Restore Point might be your last defense before you have to re-install the entire operating system.
Viewing
This error code will only appear in the Device Manager.
Right click "My Computer" and select "Properties" from the menu.
Click "Device Manager" and expand "Display adapters."
Right click on the graphics card and choose "Properties."
Under the "General" tabs is the Device status notification box.
This is where the error message will appear.
Driver Update When you're updating or downloading a graphics card driver, the drive might not install properly. Corrupt files will cause drivers to not load and the message will appear.
In the case of downloaded driver problems, remove the offending driver and re-install from a different download.
Open "Device Manager" and find the problem graphic card entry.
Right click the device and pick "Uninstall" from the menu.
Reboot the computer to force the system to try to restore the driver.
System Restore
When there are major issues with the graphics card drivers, a system restore is one option to fix the problem.
Open up the "Start" menu and type "System Restore" in the run box.
The computer looks for any entry containing "System Restore."
Click "System Restore" under the Programs listing.
This will start the program, and you can restore the computer back to a point when the graphics card drives were working.
Click start control panel administration tools computer management device manager scroll through all of your devices
If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
If you computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt which can take hours
http://download.cnet.com/SlimDrivers-Free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
How to solve mscank error
Mscank is a system driver file which may be associated with any hardware device.
Open device manager to check which hardware device is not functioning properly on the computer and uninstall it.
a) Open Device Manager by clicking the Start button.
b) Click Control Panel, click System and Security, and then, under System, click Device Manager.If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
c) Now check if any device has any yellow exclamation mark on it.
Once you find any device with any mark, right click on that device and later click on Uninstalloption and restart the computer and check if it works.
If you are unable to find any device with any marks then check by enabling hidden devices.
a) In the device manager click on View and later click on show hidden devices and check if you find any device with exclamation mark and uninstall it
If the above step fails run Windows update to check and install recommended device driver update on the computer.
Update a driver for hardware that isn't working properly
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
If all the above steps fail then contact the manufacturer to get the driver update for all the device connected to the computer.
2answers
Shows on device manager and had a question mark sign that informing it has a problem
uninstall the marked device. scan for new hardware. if it doesnot work select the device then update the driver. if still not work find the actual driver then install it.
Device is not working properly, the light comes on, but it does not show up on the desktop, or anywhere on the computer. I have tried on different computers, and have used different firewire cables,...
sounds like a driver issue
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
1helpful
3answers
Propleam with bcompaq tc 1100 audio driver
Driver errors.
Go into Control Panel and select Device Manager.
Look down the list of services and click on the missing sound driver, (click on whichever one is highlighted or has a sign on it telling you it is not working properly) and select Update Drivers within the drivers sub menu. Let Windows do its stuff or let the computer find it within System or System 32 directory on your hard drive. If it can't find it, let Windows find a driver on the internet or better still, download the driver from the manufacturers web site.
Hope this helps.
My ISATAP Adapter #4 is not working properly because windows cannot load the drivers required for this device. I am not able to connect to any internet networks even a LAN or use broadband modems
Look down the list of services and click on IDE/ATAPI Controllers.
Click on whichever one is highlighted or has a sign on it telling you it is not working properly and select Update Drivers within the drivers sub menu. Let Windows do its stuff or let the computer find it within System or System 32 directory on your hard drive. If it can't find it, reinstall Windows as it seems like it may be corrupt.
Hope this helps.
My problem is that my system does'nt show any dvd drive in Lap
I had the same problem, it occurred right after windows installed sp2 and my laptop showed no dvd player with any program, I restored my laptop to the previous day before the update and it worked fine again, after that I just let windows update by itself and it has been a week and everything is fine, also in device manager open the dvd + sign and right click your dvd and click update drivers, if that does not work, right click your dvd, and then click delete, and then reboot your computer, laptop whatever and the computer will automatically recognize the player on startup and it will install again and hopefully that will get your drivers updated, do not worry about deleting the dvd player, it will reinstall all by itself, just have to reboot..thanks
steve
2answers
Pioneer dvd-rw dvr-k17 problem
it's windows problem.
basically you need to edit (delete) registry.
follow this step from microsoft.
http://support.microsoft.com/kb/314060
2answers
GMA 4082n device driver not working properly code 39
The dvd does not need driver, you need to reinstall Windows.
Top Coolmax Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Coolmax Computer and Internet Expert? Answer questions, earn points and help others
