SOURCE: copystar CS-1815 reports a paper jam at the document processor
Check for debirs in the unit that could be tripping the jam sensor if not the sensor has gone bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: i need help to install
Its very easy let me know wat you want to do or if you want to send you the manual.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
SOURCE: Copystar CS-1815 waste toner
There are two screws on the drum unit. They are on the left hand side and one on the right hand side. Remove the screw from one side and take off plastic small side cover. Dump the waste toner. Do the same for the other side and then put it back together. Turn machine off then on and the error code should be gone......
SOURCE: My kyocera copystar CS-1815 shows in the message
Hi there just open it up and inside there will be a small plass bottle that hold the waste toner you can clean out and put back.
SOURCE: i need to find out
Have you seen this answer ? http://www.fixya.com/support/t2532905-get_scanner_work_just_set_up
