Hi sonny31,
To connect to a printer on a network
Open Printers and Faxes.
Double-click Add Printer to start the Add Printer Wizard, and then click Next.
Click a network printer, or a printer attached to another computer, and then click Next.
Connect to the desired printer using one of the following three methods.
Searching for it in the Active Directory
If you are not logged on to a domain running Active Directory, this method will not be available.
Click Find a printer in the Directory, and then click Next.
If needed, change the default printer location listed in the Location field by clicking the Location Browse button, and then choosing the appropriate location.
Click Find Now.
In the list that appears, click the printer you want to connect to, and then click OK.
Typing the printer name or browsing for it
Click Connect to this printer, or click Next to browse for a printer.
Do one of the following:
• Type the printer name using the following format, and then click Next:
\\printserver_name\share_name
• Browse for it on the network by clicking Next, locating the printer in Shared printers, and then clicking Next.
And Thanks.
Click on this link directly to get the exact drivers for your printer http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&subtype=DownloadHelp&fcategoryid=2269&modelid=8927 also to get driver for other online sites please click on this link directly http://www.printcountry.com/drivers/CANON_IMAGERUNNER_C3200_DRIVER_DOWNLOAD.htm ------ but as you mentioned that there is a virus problem in your operating system then i suggest you to get the operating system formatted first by a local pc repair tech then install the driver, because if there is a problem of virus in your system then the new drivers will also not work due to this viruses. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Restart unit and reconnect to network.
sorry, we had a long holiday here. but please if problem still unsolved, reply to this post so that i may proceed with helping you. meanwhile, download its drivers from here and install them.
Regards
I tried shutting down still no connection----my network isn't reconizing up my printer--lost my driver access--had a very bad virus--probley need a disk to reinstall--can't seem to find one --tried canon corp. they just steer me away to some other company..need ideas--help
I had a tech clean out the virus--in doing so I lost my connection for my printer--I did what you suggested --when I go to add printer--the network does not pick up the hardware--I downloaded canon Xp-- I tried --USB--TC_IP and others still no connection---do you think if I get a insalltion disk would that help
Thank You
