I have a PS3 that was hooked up to an hdtv I gave it to my son who will have to use the AV Cables and its not working. I know its hooks up like a ps2 but cant get no vid. Help
First make sure that all of the connections are securely connected. If it still doesn't work try another set of cables. Also ensure that your setup menu on the PS3 is set to the correct resolution. If you are using the standard definition connection (3 RCA type connections labeled VIDEO L-AUDIO-R) make sure your resolution is set to 480i. If all of those steps are correct and you still can't get it to work then your Analog Video board might be defective. You will have to get this serviced by your local PS3 repair center.
Plug it in to the tv and get the right channel then hold the power button till it beeps twice then it well work just fine have a nice day
