Question about Whirlpool LSQ8243H
Washer fills but then stops just makes a humming sound.will not agitate or spin. i have replaced the timer and still have the same problem??
    Sergeant:
  • 215 Answers
Hi, sorry to hear you replaced timer on machine, but it is most likely the motor.
Posted on Mar 04, 2010
5 Suggested Answers
jumptrout51
steve
  • 3361 Answers
SOURCE: will not agitate
Replace the direct drive coupling. Directions are in the attached video.
Posted on Apr 03, 2009
Bill Eager
  • 459 Answers
SOURCE: washer fills but won't agitate or spin. Makes a
Is the belt operational?
Posted on Dec 27, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Maytag washer, model # PAV1000AWW
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 70 series washer making humming sound and won't agitate
Posted on Sep 14, 2010
oldTech2332
Gene Meier
  • 2341 Answers
SOURCE: Maytag A512 clothes washer will
With the motor not coming on it sounds to me like the timer is going to be the problem and the contact in the timer for the motor to rotate in the agitate direction is burnt out. The part number for the timer is 206230 The timer could be ordered from your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE..OldTech2332
Posted on Aug 31, 2011
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
I recently replaced the broken drive coupling on my whirlpool washer but it still won't agitate or spin. Could there be an electrical issue with the washer lid switch?
If it sound like the motor is running and you get no agitate or spin but it drains, and the couple is new, then you have a bad transmission. If the washer makes a hum like the motor is jamb, then look inside the pump. If the washer make's no sound at al after fill then the lid switch in normally the problem, but secondary problems could be faulty timer or motor.
Mar 26, 2015 | Whirlpool Washing Machines
Washer wont agitate
sorry only the local washing machine engineer is the only hope eric
Jan 01, 2018 | Washing Machines
Will not Agitate (Frigidaire GLWS1233AS1) The washer fills and then stops. If I manually change the timer to the end of the cycle it drains and can spin. I saw on older posts that this might be a...
When ya say after filling "the washer stops" does that mean it is not making any sorta sound?? if it is the transmission,agitator block,or evena stripped gear you will hear the motor running yet it will not agaitate and from reading your question i think it says their is no sounds yet instead it fills then just sits their silent,is that so??
If yes their is no sounds it could be in the area of the timer where the problem lies, since it will drain/spin i am exluding the motor, lid switch or belt as the problem.
If it does make sounds yet just wont agitate it could be a stripped agitator block, or stripped gear but,the belt would be ok since it spins
GENE
Oct 25, 2011 | Washing Machines
The washer will fill up with water but it wont start washing or drain or spin you hear a humming noise then everything stops. Then in about 5 mins it will hum again then stop again
If the washer will not agitate, spin or drain it's a motor problem, capacitor or a broken motor coupler. It's either a loose wire connection on the start circuit or failed contact in the timer. When you say that the motor hums during spin, that would indicate that the motor has run voltage, but it has no start voltage. It needs both start and run voltage in order to get the motor started and running. The start voltage gets the motor started, and once started all it needs is run voltage to keep it running. The only difference between agitate and spin is that the polarity is reversed in order to start the motor in the opposite direction. The reversal of the polarity is controlled by timer contacts 7 and 14.
Most likely it's a timer or loose wire connection.
Jan 22, 2011 | Estate ETW4400VQ Top Load Washer
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Washing Machines Logo
175 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
