Ovens Logo
Posted on Mar 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My electrolux eod33002 bottom oven does not heat up but light and fan work. The top oven works OK
Anonymous
Level 2:
Director Badge:
Uploaded 100 video answers.
  • Expert 213 Answers
  • Posted on Mar 04, 2010
Anonymous
Expert
Level 2:
Director Badge:
Answers
213
Questions
0
Helped
150341
Points
436
If youhave a ELECTROLUX electric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fan motor in theback of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from our websitethese can be tested with a electric meter.
To gain access to the ELECTROLUX element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if you look closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is opencircuit i.e. broken inside the element casing, either way it will needreplacing. Some elements will are fixed from inside the oven and some are heldin place by nuts from the rear of the machine.
2, If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
3. If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
4, A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
I have a eob6630 Electrolux cooker. Top element / bottom and work ok. But oven cuts out approx 20 mins when cookin. Then switches off. But comes back on when cools. Approx 20 mins. Can anyone advise about...
From my experience the most common reason for this failure is a thermal switch for cooling fan. It is located on the upper side between the wiring and its function is to switch off the cooling fan when the temperature drops even though the oven is already turned off. If the cooling fan does not work then it will increase the temperature on the cabinet and the main temperature limiter will switch off the oven.
Dado
The bottom oven in my Electrolux EOD33002 does not get quite as hot as it should.
it doesnt have anything to do with keeping heat away. yes you need it to hold it in plave, you can get that tape from lowes and homedepot. same thing they use on duct work
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
1helpful
Electrolux EOD 985 bottom oven over heats burnng food
thats because the heat sensor isnt working properly need to replace
Apr 25, 2012 • Ovens
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I...
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
1helpful
8helpful
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
2helpful
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
3answers
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
2answers
Oven not working
is this a gas oven or electric?
Top Electrolux Ovens Experts
john h
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
